Harman kardon 688 e90 subwoofer upgrades?
03-15-2016, 03:44 PM | #1 |
Rep 16
I do have option 688. Iam satisfeid with the audio but not the bass. It seems that all the bas is coming from the speaker below the seats. I usally like to have some fader adjusted to the back. When i do that all the bass disappear.
The indivudual setup is more powerful. Can i buy a set and change all the speakers and code it? I have found a set on ebay. Also i have read that i can buy a harness that make it possible to install a subwoofer. What is the best way tn do it? |
03-16-2016, 03:36 AM | #2 |
20
Rep 105
Have upgraded whole parts from HiFi to individual and must say that HiFi had more Bass. And with individual they aren't the same at low or loud level. Take care if you take the individual Ampli you MUST change the Bass (2 ohm HiFi and 4 Ohm with individual) or will heat and burn the Amp. But must say that medium and treble are very clear when I put the power!, details about this retrofit could be found there:
http://www.1addicts.com/forums/showt...php?p=19129247 |
03-16-2016, 12:11 PM | #3 |
1915
Rep 13,107
Most people with a L7 just add a sub and sub amp
Most people with a L7 just add a sub and sub amp(10" or larger trunk sub)
for big bass. subwoofer threads http://www.e90post.com/forums/showpo...2&postcount=66 http://www.e90post.com/forums/showth...t=Ultimate+Sub http://www.e90post.com/forums/showth...ight=subwoofer when you say best do you mean best or most cost effective. |
03-16-2016, 02:43 PM | #5 |
458
Rep 2,754
this setup will have problem because factory amplifier is time-aligned in a such way that sound from woofers comes from under the seats
when you put woofer in trunk, sound come bit later and not synchronized with other speakers this will work only if you remove your harman kardon or individual system and replace it with the following set most-rca converter, dsp processor or amplifier with dsp, and additional amplifers on channels after that you have to tune all this system the budget of such system close to 1500-2000 eur
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
