Reprogramming Window
03-13-2016, 11:43 PM | #1 |
1250
Rep 1,501
Just replaced the window regulator on the PS rear window of my 07 E90 335i. I've searched and YouTube-d and can't seem to get the anti pinch reprogrammed. What am I doing wrong!?
2011.5 E90 M3 DCT ZCP Slicktop
03-15-2016, 02:09 AM | #3 | |
happy.
138
Rep 464
Have you tried this method?
'09 Jet Black E90 335i | BMS DCI | Forge DV | VRSF CP, DP, 7" FMIC, Exhaust | MHD Stg 2 / 93 Oct | Koni Yellow / H&R Sport | Mooooarrrrrr
this list is getting too long..... |
03-15-2016, 05:37 PM | #5 |
douchebaggo
186
Rep 972
These are the steps from BMW:
Operating sequence for initialization: · Move side window into lower end position. · Press switch into "Open one-touch operation" (second switch position) for approx. 15 to 25 s and hold down. · Release switch, then immediately press into "Close one-touch operation" (second switch stage) and hold down. · The side window now moves to the lower end position and then back to the upper end position. Initialization is completed once the side window has returned to the upper end position. |
03-16-2016, 11:39 AM | #6 |
1250
Rep 1,501
I got it to work! none of the above steps worked to the t, but in playing around this the switch on the PS rear door, I got a window ! symbol in the dash, which hadn't happened before. I then tried to hold down and when rolling back up it would go a few inches then stop, so on and so forth until it reached the top. Then it was fixed. Could not tell you how to get it to work, but seems like that error symbol on the dash was the only variable that made it work this time.
