03-13-2016, 11:42 AM | #1 |
98
Rep 305
Max Power OEM 676 Speakers Can Handle?
Anyone know, or even an approximate guess? Reason why I ask is I just found an amp Ive had for a while, completely forgot about it. I'm temped to amp the stock speakers or maybe just the subs.
Def overkill and shouldnt bother? Specs via SonicElextronix- http://www.sonicelectronix.com/item_...-MRV-F545.html Power Specifications - Full Range Channels RMS Power @ 4 ohms 125 watts x 4 channels RMS Power @ 2 ohms 250 watts x 2 chan. (3/4 Only) RMS Power @ 1 ohm Not Stable Bridged RMS Power 500 watts x 1 chan. (3/4 Only) Total RMS Power Output 500 watts Maximum Input Gauge Size 4 AWG Minimum Impedance Unbridged 4 ohms (Ch. 1/2), 2 ohms (Ch. 3/4) Minimum Impedance Bridged 4 ohms THD at Rated RMS Power 0.3% Speaker Level Inputs No Preamp Outputs 1 pair Built-in Crossover Low-pass (LP) High-pass (HP) High-Pass Crossover Frequency 30 - 400 Hz, 600 - 8000 Hz Low-Pass Crossover Frequency 30 - 400 Hz, 600 - 8000 Hz Signal-to-Noise Ratio 93 dB |
05-29-2016, 03:42 PM | #4 |
92
Rep 267
I don't think this would be much different than the power available with the bimmertech power amp upgrade that many here do. The bigger issue is getting a wiring harness to adapt this amp into the BMW wiring harness. Obviously don't overdrive the speakers, if you hear some "crackling" noises, then obviously you have the volume to high. But otherwise, there's no harm in using an amplifier with a higher rated power output as long as you don't crank things to "11" all the time.
2017 430ix Gran Coupe
05-31-2016, 02:04 PM | #5 |
355
Rep 1,986
A lot of Clean power can go to decent speakers with no damage. The issue is clipping will destroy the speakers quickly - and most amps get into clipping rather easily.
