2006 325xi dead battery. Cranks. No start *FIXED*
03-10-2016, 09:01 AM | #1 |
19
Rep 76
Drives: 2006 325xi
Hi guys,
I'm an e46 guy who tried to convert to an e90 on a budget. Anyhow to the issue. I bought a 2006 325xi automatic with 186,000 miles. Owner said the car wouldn't start one morning in December and he hasn't touched or moved it since. It passed the emissions on December 1st so before this happened it had no check engine lights present. Bought the car as-is figuring it couldn't be so difficult as it was running and driving before he parked it the previous night. Currently battery is beyond dead as its been sitting for nearly 4 months in the winter. Towed the car home. Tried to jump start it. Everything works inside and outside electrically. Except the car will not fire. It will turn over but won't run. It will sputter and then just keep spinning. I bought gas to be on the safe side. Any thoughts or ideas are welcomed before I burn up another tow to the Indy shop. Thanks in advance Last edited by GTA_G20; 03-30-2016 at 10:26 PM.. Reason: repaired |
03-10-2016, 12:11 PM | #2 |
1918
Rep 13,116
IBS could be blocking the start.
These cars are hard to start with just a jump . Battery could be sucking down the voltage did you put a full charge on it? 1) The Ibs system will keep the car from starting . 2) If you change the battery there is a lot of stuff to plug back in right on the battery distribution block and there is a shipping cable that is not suppose to be plugged in that will also stop it from starting. 3)starter is bad 4)ground strap to engine is bad. Do not use battery back up if changing the battery it blows the instrument panel fuse. And doesn't back anything up anyway. Try disconnecting the ibs cable at the battery to see if it will start. electical e90 pdf http://www.google.com/url?sa=t&rct=j...,d.cGU&cad=rja http://www.google.com/url?sa=t&rct=j...85464276,d.cGU http://www.google.com/url?sa=t&rct=j...85464276,d.cGU 6 years is the average life on these battery's if the car is driven enough to keep them charged. The e90 is a battery hog much more than a e46. Last edited by ctuna; 03-10-2016 at 12:23 PM.. |
03-10-2016, 12:36 PM | #3 |
19
Rep 76
Drives: 2006 325xi
Thanks for replying.
1) I'll search more on IBS now 2) I just disconnected the battery which is completely dead. I lifted the electrical block ontop of the battery. I cannot however life the battery out without breaking something so I stopped will tackle it again later. I noticed the shipping cable which I was wondering if the reason it wasnt starting was because this plug was not connected lol 3) The starter is good. The engine rotates and it cycles but it just wont fire. Im thinking its fuel related because everything else is working off a boost 4) Just gonna do the battery first and see what happens Just found out its not an OEM battery its a NAPA branded battery |
03-10-2016, 02:19 PM | #4 |
Beamer Mantic
82
Rep 1,191
I'm sure you found it, but just in case - there is a battery lockdown bolt on the taillight side of the battery and a wedge piece at the bottom that will need removed to retrieve the battery.
2006 325i
2006 M5 2008 X5 4.8i 2014 X5 50i M-Pkg |
03-10-2016, 02:56 PM | #5 |
1918
Rep 13,116
There are many battery changing DIY's
Better look them up and read them as BMW has made changing battery's a big task with lost of gotchas. The ibs is described in the first electrical pdf I posted. There are many sub forums here including a DIY and maintenance sub forum. Also there are a lot of DIY's on ytube. http://www.e90post.com/forums/forumdisplay.php?f=16 |
03-14-2016, 01:17 PM | #6 |
19
Rep 76
Drives: 2006 325xi
New battery installed, IBS cable attached and removed and the car just cranks and cranks.
I would think it is a crank position sensor issue. But with this car Im sure its some other kind of electrical programming needed |
03-14-2016, 02:03 PM | #7 |
19
Rep 76
Drives: 2006 325xi
DDE and EWS?
03-14-2016, 08:44 PM | #8 | |
14
Rep 255
03-14-2016, 10:21 PM | #9 |
19
Rep 76
Drives: 2006 325xi
cannot hear the fuel pump. Gonna purchase a Kcan cable and stop messing around
03-15-2016, 08:33 AM | #10 |
117
Rep 622
Battery should be good if you say it turns over and sputters, 3 things needed to ignite, air, fuel and spark. Air filter should be easy to check, also pull the coils and make sure the spark plugs are not covered in oil, If the valve cover gasket is leaking onto the spark plugs they wont provide a spark, just a few easy checks before you tackle the fuel system
Good Luck! |
03-17-2016, 08:08 PM | #11 |
19
Rep 76
Drives: 2006 325xi
Ctuna. You were bang on.
Jbbf.. A6FC 9C69 MRS.. 93C3 DME.. 2E8C DEC. . 5F12 Pulled these codes |
03-17-2016, 09:12 PM | #12 |
1918
Rep 13,116
Which software did you get ?
ista d is the easiest as it gives you a direct interpretation and suggested troubleshooting procedure. Inpa is good if you know what your are doing with it. See coding sub forum. |
03-18-2016, 09:06 AM | #13 |
19
Rep 76
Drives: 2006 325xi
Had someone come and help me pull the codes.
ISTA was used as we couldnt understand INPA Tried again this morning after removing and reinstalling the negative battery cable and pulled more DME codes 2E8C 2CF9 2CFA 2D1D 2D09 |
03-18-2016, 12:13 PM | #14 |
1918
Rep 13,116
What's the battery voltage did you clear and rerun
Without the description or a working copy of ista to lookd them up its kind of hard to know what they are. Are you sure some of those aren't shadow codes which say clear but not present now. There are some codes generated by a battery disconnection as well. The the reason for clear and rerun though I would print out a copy of what is says before clearing. |
03-21-2016, 01:28 PM | #15 |
19
Rep 76
Drives: 2006 325xi
Battery voltage after a few failed attempted starts is 11.7 volts
I unplugged the skinny IBS sensor plug and no change pulled codes are JBBF A6CF - air circulation sensor on radiator 9C69 - rear cabin heat conrtol. (removed due to broken fins) MRS 93C3 - passenger seat occupancy/srs sensor DME 2E8C - intelligent battery sensor, function 2CF9 - Throttle-valve potentiometer 1 2CFA - Throttle-valve potentiometer 2 2D1D - accelerator pedal module, pedal sensor 1, voltage suppy 2D09 - Throttle valve DSC 5F12 - front brake pad wear 94BB - steering angle sensor internal fault C998 - wheel tolerance control failure/Insignificant SZL fault 5EBA - steering angle sensor |
03-21-2016, 01:49 PM | #16 |
1918
Rep 13,116
The only thing that would stop it from starting
The only thing that would stop it from starting that's
related is the DME codes. How far does the battery voltage drop when you try to start it. 11.7 is not a very healthy battery voltage if the battery is more than 6 years old or has been abused by lack of use you are due for one. Some of the other codes might go away with a healthy battery. |
03-21-2016, 01:53 PM | #17 |
19
Rep 76
Drives: 2006 325xi
I'll get an OEM battery
thanks |
03-21-2016, 08:33 PM | #19 |
19
Rep 76
Drives: 2006 325xi
No its a Napa International, had it tested looks new and shop said it was good
03-21-2016, 10:37 PM | #20 |
1918
Rep 13,116
Shouldn't matter if its OEM or not
it just needs to be the right size and type . You should be seeing 12.4 to 12.6 volts if the motor is not running and you should see about 14.5 with the motor running . And if it sets overnight the static voltage (12.4 to12.6)shouldn't drop very much . |
03-22-2016, 08:20 AM | #21 |
19
Rep 76
Drives: 2006 325xi
It was at 12.4 volts but after cranking on it quite a few times voltage did drop off some
