noise coming from RR dps
03-05-2008, 05:08 AM | #1 |
30
Rep 838
i got my dp installed yesterday everything was good...the next day i start the car and there is a noise that sounds like a chain rattling, so i start driving and i get the service engine soon light and it says power reduced on the i drive. then i lower my window and i can hear the rattling sound from 1K rpm to 3k rmp. I was just wondering if anyone has had this problem and what it can be or did the mechanic put the pipes in wrong ?
03-05-2008, 05:17 AM | #4 |
43
Rep 1,683
either your shop screwed up, or a cracked weld...
i would just take it straight to RR and have them check it out...
Life is Good
03-05-2008, 06:00 AM | #7 |
33
Rep 496
is the rattle during acceleration, deceleration, idle, or all of the above??
Manny : 2008 335xi sedan : SG, Terra, Alum, 6mt, SPP, PP, 162s Mods; Procede V4 | Remus Quads | UR catless dps | H&R coilovers | Modified CDV | Injen Intake | Spearco IC | Forge DVs | Defi Boost Gauge w/controller | Vorsteiner CF Hood + Front Lip | OEM M-tech Body kit | Hamann eyelids | Predator Ice Angels | 19" Volk Progressive Me's | Rotora BBK | 18" Rota Torques w/Blizzaks |
03-05-2008, 07:50 AM | #9 |
Rep 35
I also encounted that. However, mine's a RHD. Seems that one of the pipes is very close to a "wall" which cause the rattling sound. Went back to the workshop, and they put a thick piece of rubber from a hose in btw, so far, have not got any rattling for a week. My workshop have to take out a metal plate from the side as it was too close to fit back. I'm not sure if rest have similar problems on a LHD car.
03-05-2008, 07:50 AM | #10 |
168
Rep 2,114
sounds like an install issue... the chance of a weld breaking is slim to none.
Take it back to the shop you had install them. I have done over 10 installs on these and nothing has happend like you descibed...... just that no one can get traction anymore If you would like you can always bring it to me and ill check it out... there is a certain way to postion the DP's or "clock" them when they are on the turbo... they will move the left and right a bit when you clamp them on the turbo before you tighten them... let me know if you need help. |
03-05-2008, 08:21 AM | #11 |
Rep 115
regardless of the origin of the rattling sound, it is unrelated to your check engine light...from what I've read, you need to get Terry's o2 sims and you'll be fine...
regarding the rattling, that's got to be a simple install issue, take it back and have them look at it, I'm sure it can be fixed easily |
03-05-2008, 01:02 PM | #13 |
Aberry is a scammer
559
Rep 5,507
Drives: SGM E92 335i, AM E90 335i
you should take it back to the shop and have them figure it out since they were the ones who did the install. gl, keep us posted.
03-05-2008, 02:40 PM | #16 |
168
Rep 2,114
03-05-2008, 03:06 PM | #17 |
Rep 178
I am also having a similar problem. I had the RR DP's installed about a week ago and I'm now having a severe ticking sound coming from my engine bay. The research I've done from other e90 postings states the problem could be a wastegate issue. This will be a time consuming process if I have to remove my mods and bring the car into the dealership. Whats the chances of this rather then the DP's or heat shield of some sort touching? The ticking noise speeds up as the engine revs as well.
Thanks, YB |
03-05-2008, 03:10 PM | #19 | |
81
Rep 849
08 E92 335xi Space Gray 6AT - PROcede V2 12.8 @ 111 mph
03-05-2008, 05:38 PM | #20 |
30
Rep 838
i didnt have time to take it to the shop im going to take it tomorrow its kind of like the problem that youngbuck is having its like a rattling or ticking noise but id say it sounds more like a bunch of little metals shaking
03-05-2008, 05:39 PM | #21 | |
79
Rep 1,310
Drives: 2006 Interlagos Blue BMW M5
Fitment issues, most of the time, are when the mechanic (other than RR approved installers) tighten the top turbo clamp too tight when installing the actual catback. Make sure the turbo clamp is on loosely and install the catback, then tighten both. |
03-05-2008, 08:12 PM | #22 |
Dancing Machine
47
Rep 1,419
also make sure the o2 sensors are installed in the correct pipes not switched or your ECU will get contradictory signals which would explain why it took a while to foul as it perpetually corrected in the opposite direction it was supposed to
2007 e90 & 1981 Corvette Predecessors: 2007 BMW 335i E92, 2006 M5, 2008 Viper SRT10 Coupe, 2005 Viper Yellow, 2006 Corvette Z51, 2009 Challenger SRT8, 2006 S4, 2001.5 Nogaro Blue S4, 2006 GTI w/ DSG, 06 Evo IX, 04 S4, 04 911x51, 03 Evo VIII, 98 Eclipse GSX, 96 GST, 92 Galant Vr-4, '70 Grand Prix Model J, '70 Nova, '68 Firebird
