Electronic steering lock
03-03-2016, 11:11 AM | #1 |
50
Rep 132
Hi,
I'm looking for the best remedy to this fault as my 2007 E93 335i currently will not start and has been abandoned, The warning is amber but it will not disengage. Please help. Thanks |
03-03-2016, 11:45 AM | #2 |
1918
Rep 13,116
There us a DIY on this topic in the DIY or maint
section . You can sometimes get it to go by jiggling the wheel with the ignition on . Basicly the ELV is not designed to last and you have to remove the upper steering column and replace it or clean the mechanism and or there is a spoofing device that will bypass it . There is a software counter that allows you a certain number of trys before it goes red then the car can't be started until the counter is reset with and external programmer. https://www.avtotools.com/index.php?productID=437 http://www.e90post.com/forums/showth...&highlight=ELV |
12-11-2016, 07:45 PM | #6 |
1918
Rep 13,116
From entry 73 in the long thread
If you have completed this DIY (thanks yakev724) and still get that pesky yellow warning light, I found a way to clear it (credits to Micha from the German e60-forum.de). Apparently the ELV has an internal counter that causes the yellow (and red?) warning light to display. This counter can be reset using EDIABAS ToolSet32. The count is stored in the CAS and needs to be cleared in CAS and ELV. Load CAS.prg in ToolSet32 and run the commands "steuern_elvcounter_cas_loeschen" and "steuern_elvcounter_elv_loeschen". This procedure may even unlock the locked steering column with red warning light, but I haven't had the red light since I performed the DIY. I'm assuming this because after my steering column was locked and I had towed my car to an indy shop, the mechanic was able to unlock it by "resetting" something. |
VTECaddict481.00 |
