2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions Carly for m235i?
      03-03-2016, 10:16 AM   #1
nicholascanada
49
Drives: Acura
Carly for m235i?
Is it possible to use Carly for the M235i for coding? From what I gather it looks fairly straight fwd vs the other option.
I just want to code the digital speedo, but after reading the Esys stuff I am still a bit perplexed how it all works (VAGCOM was fairly easy..this seems a bit more confusing).
So I noticed Carly can code but not sure if anyone has used it for the 2 series..as it seems to recently been added to the F series? Thanks.
      03-03-2016, 01:33 PM   #2
pyroboy024
Drives: 2016 ///M235i
F2x (2013 - now)
Diagnostics: ✓
Coding: ✗, see here
Engine-Parameter: ✓, test with lite version
Service Reset: ✗, see here
Battery Registration: ✗, see here
Diesel Particulate-Filter: ✗, see here
      03-04-2016, 12:30 AM   #3
jediknight0
Drives: M235i
Take a look at their 'current projects' link: http://www.mycarly.com/projects/bmw-app/
Coding for the F-series is in 'internal testing'.
      03-04-2016, 01:16 AM   #4
pikcachu
pikcachu's Avatar
1399
Drives: M235i (F22 Red angel)
ya like you code tire pressure temp and the mirrors fold up
      04-04-2016, 02:58 PM   #5
djarchow
64
Drives: 2020 M4 ZCP
Assuming F series programming in Carly gets to the capability level of the other BMWs will Carly eliminate the need to use the ENT cable and E-Sys?
I want to get an OBD adapter for my car but like the additional security of the OBDLink vs. the one used by Carly/BMWhat. If I am going to need to get the cable and learn the software anyway I will just get the OBDLink and use with Torque. If Carly will handle the coding and provide data to apps like Torque I will go with the lesser security and use the Carly adapter.
Thanks!
      04-05-2016, 09:39 AM   #6
RoundelM3
RoundelM3's Avatar
1837
Drives: 15 F80 M3, 22 G01 X3 30i
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Thanks!
I've been a Carly user for quite some time, primarily for coding my wife's previous 128i convertible and diagnostics/code reading and clearing on that and my 2013 335i. Coding for F-chassis cars was supposed to be available at the end of 2015, and now we're into the 2nd Quarter of 2016 with coding still in "beta testing". Even at that, I read that initial coding capability will probably be limited to just the KOMBI (dashboard) module and not much else, unless they've expanded their coding plans.
As much as I like Carly for coding older models with their Bluetooth adapter, I'm a bit disappointed in their inability to get coding finished for F-chassis now that those cars are in their 4th year of production. While the E-chassis cars used a "bus" system, the F-chassis uses an actual network, hence the requirement for the ethernet cable used with E-Sys and the Gen-2 adapter for Carly.
We just took delivery of a 2016 228i M-Sport convertible (F23) to replace the 128i, and I had to use E-Sys 3.27.1 and a newer psdzdata plus the E-Sys "launcher" to code the new car. Once you get the hang of it, it's really pretty simple to do FDL coding for KOMBI, FEM_BODY, and HU-NBT2 modules. I'll continue to use Carly for reading/clearing codes and their other features, but I'm afraid it'll be a good while before their coding capabilities will allow you do more than just the KOMBI features.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey
Appreciate 2
      04-05-2016, 10:12 AM   #7
djarchow
64
Drives: 2020 M4 ZCP
Thanks for the detailed reply. I appreciate it! I ordered Carly's bluetooth adapter and will try out their lite version of the tools as well as Torque and keep an eye on the coding progress.
      04-06-2016, 10:14 PM   #8
djarchow
64
Drives: 2020 M4 ZCP
I received my Carly Bluetooth adapter today and tried it in my 335is with both Torque and Carly on Android. Torque seemed to have no issues and as an example, the tach gauge matched very closely to the real tach in the dash. On the other hand, the tach gauge in Carly seemed to be running 2-3 seconds behind the real tach. Is that normal?
Thanks!
      04-07-2016, 08:36 AM   #9
RoundelM3
RoundelM3's Avatar
1837
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
From my experience with Carly, yes, the tach reading seems to lag behind the car's tach. Not sure why there's so much latency. You can adjust the connection speed settings in Carly to see if that might speed things up.
      04-07-2016, 09:14 PM   #10
djarchow
64
Drives: 2020 M4 ZCP
Thanks I appreciate it!
      04-08-2016, 08:19 AM   #11
RoundelM3
RoundelM3's Avatar
1837
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
No problem. I'm watching closely at each update of Carly to see when they'll finally release their F-chassis coding capability. But honestly, it was not all that complex to use E-Sys and code all the things I wanted instead of just dashboard features. From what I can tell, there's only 3 modules that you can actually do useful FDL coding with, so maybe they'll release coding for all of them instead of just KOMBI.
      04-22-2016, 12:45 PM   #12
rwrwrwrw
No_Country
36
Drives: Car
2016 M235i  [0.00]
Hi,
I just noticed on Carly website that BMW F2x (2013 - now) is now available.
Anybody try this on M235i?? My car is coming end of May and I would like to do some minor coding (LED lights etc). I think this looks pretty easy to use with iOS. It looks like Android not yet available.
Cheers.
      04-22-2016, 02:36 PM   #13
RoundelM3
RoundelM3's Avatar
1837
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Haven't used it for code-checking/clearing yet, but the F-coding is still not available, despite numerous recent updates to the application. We're now in Q2 of 2016, F-coding for Android was promised by Q4 2015 - they keep saying it's still being "tested". Frankly, I'm relegating Carly to diagnosis and other functions and doing coding with E-Sys on both of our F-chassis cars. Pretty disappointing that it's taking them this long to get the coding thing down, especially since their coding for E8x and E9x cars works so well. Apparently the new network vs. the old canbus interface has thrown things way off schedule.
      04-28-2016, 07:48 AM   #14
nelsdvn
Gangnam Member
nelsdvn's Avatar
229
Drives: '17 M2, '15 X5d
F coding has been released on Carly. Pretty limited right now. I only show two available ecu's for coding. KOMBI and Lights.
Current: 2015 BMW X5d | 2017 BMW M2 | 1976 BMW 90S
Gone but not forgotten: 2016 BMW 228i, 2014 BMW 228i, 2008 BMW 535xiT, 1998 BMW 328iC, 1991 BMW 325iC
      04-28-2016, 07:57 AM   #15
RoundelM3
RoundelM3's Avatar
1837
2022 BMW X3  [9.83]
2015 BMW M3  [6.50]
Is that Carly for IOS or Android? I just got an update last evening on my Android tablet and there was still no F-coding available. If all it's going to cover is KOMBI and not FEM_BODY and HU-XXX, it's not really going to do much. I really like it for code reading/clearing and parameters, though.
      04-28-2016, 09:45 AM   #16
nelsdvn
Gangnam Member
nelsdvn's Avatar
229
iOS and you're right. Not doing much right now.
      12-10-2016, 07:22 AM   #17
Boosted Autos
147
Drives: M235i
Bumping this thread. Looks like the newer version 22.90 works with F22 fully supported now.
Anyone using it? Keen to get this happening but don't want to drop the $ on the adaptor if it's not going to let me do coding, and can't test with the free app without the adaptor.
      12-10-2016, 07:38 AM   #18
Matt-F22
Drives: Estoril Blue M235i
Boosted what are you looking at coding with Carly? I have and used it to code loads into my E82 coupe.
The F22 is a bit more restricted, but there's constant updates adding extra coding options for F22's.
So far I've added digital speedo, red sport gauges, door lights on reverse and a lot more.
I'm just waiting for audio beep on lock and unlock
2addicts
