03-03-2016, 10:10 AM | #1 |
Rep 19
Dash cam for 330xi
Hi everyone,
I am looking for a way to record the traffic in front of me, for what I've been thinking of several options: 1. buy mini camera and put it behind the grill, while recording its footage on me HDD integrated in Navigation Professional 2. buy HERO4 Seasson (200 USD). it is only 3.8mm small, easily mountable behind the grill or the rear view mirror. it supports auto start of recording upon the engine start and it can be wired to the car's installation 3. buy Transcend DrivePro 200, which is a real dash cam. Downside is that it is a little bit bigger then I'd like to. Of all the fancy features I need exactly 0 of them. What I need is only the auto start/stop of the recording once the engine starts/stops, the loop recording, fullHD with decent night recording, the smallest size of the camera possible and to be able to withstand the high temperatures over the summer. Has anyone any experience with any of the above mentioned options or maybe thoughts on what the next best alternative might be. Thank you, Gile |
03-03-2016, 05:56 PM | #2 |
84
Rep 236
I've been doing some research around the forum and the options available.
I've narrowed down to two brands; Thinkware and Blackvue. Blackvue seems to be more discrete but the video quality on the Thinkware is slightly better. I'm planning to hard wire the dash cam to my fuse box and you'll be able to set the camera to record when the engine is off (parking mode). Here's the link to one of threads. Hope this helps |
03-03-2016, 07:58 PM | #3 |
80
Rep 346
You won't go wrong to install the BMW ACE Advance Car Eye.
I also bought Hero3 and tried and there are too many limitations as it is not really designed as a dash cam IMHO. I also found night recording not very good at all. I had the Blackvue DR500 wifi and had to add T Comp so that it does not trigger any batt issue and to record when at park which is too short. Go and search for the thread on dash cam. Many discussions there. |
03-03-2016, 08:22 PM | #4 |
Sustinendum Victoriam
82
Rep 349
I second the BlackVue option. I have the DR600GW which is a one channel (front) dashcam on both my F30 and F15. It is very discrete and the video quality is great. I believe their newer models use Sony CMOS cameras for better video quality.
03-04-2016, 04:48 AM | #5 |
Rep 19
Thanks for all the comments guys.
I've been reviewing both Blackvue and BMW Advanced Aye, and truth to be told, they do not quite meet the expectations. BMW, although integrated seamlessly, is pretty big, where I'm looking for a discrete solution. Blackvue on the other hand has the GPS built in, which I see as more of a down side, because it records your speed as well. This can easily backfire on you if you had an accident because some moron cut you off, but you were driving slightly above the limit. After all...who buys the BMW and does not speed? :-D |
03-05-2016, 01:42 PM | #6 | |
Dust Bunny
98
Rep 189
2016 328i XDrive Touring M Sport EBII
03-08-2016, 06:34 AM | #8 |
494
Rep 1,076
Another cheap and reliable option is the mobius action camera with a wide angle C2 lens and a super capacitor. Sometimes they come up as a set preconfigured. I am not sure if you have a high beam assist camera in your car but if you don't then you can install it with the mirror cover plate and drop the camera in it after minor modifications for a clean install. Someone on the e90 forums has done this successfully and I hope to do it and post a DIY soon for the F3x series. Will keep you updated.
