THE ULTIMATE Intercooler Thread - What to Look For Before Buying an FMIC |
03-02-2016, 04:37 PM | #1 |
Joint Chiefs of Staff
24190
Rep 190,802
There has been numerous threads lately about intercoolers. From the usual which one is the best FMIC on the market to Ebay brands claiming to offer a high quality solution for a reasonable price.
I will be discussing the most important factors about intercoolers and why some FMIC will offer better cooling than others Intercoolers and why replacement is recommended? Turbochargers compress engine intake air which creates heat. The Intercooler then cools down the charged air. For remapped cars, temperatures up to 200°C after turbocharger can occur. Factory intercoolers are unable to sufficiently handle such high temperatures. This causes high intake temperatures and the oxygen content of the charged air drops significantly. As a direct consequence, the performance decreases, the thermal load on the cylinder head and valves increases. Worst case this can cause severe engine damage. The colder the intake air, the higher the efficiency of the turbo-charged engine and less risk of engine damage. This can be achieved with an optimized intercooler system installed between the turbocharger and engine. Construction of an intercooler? Intercoolers can be categorized by two types of the core construction. The BAR & PLATE core construction is relatively heavy so there is certain temperature inertia. Meaning under load the core takes longer to heat, but also longer to cool down once the load is removed. This is fine for on the road, but for use on the race track this core construction is not particularly suitable as it arrives at a constant cooling performance at varying loads in the full load range. Also weight reduction is an important consideration for track use. The fine structure of the TUBE & FIN core makes them relatively light and exchange heat much faster. This type of core construction takes temperatures relatively quickly, but also very quickly transfers this away again. For a constant cooling performance in a dynamic throttle situation this is an indispensable feature. Tube fin intercoolers are suitable for street use as well as at the race track. The OUTSIDE CORE is responsible for heat exchange with the running wind. The higher the density of the external core (fins), the better the cooling performance of an intercooler. But you also have to look which parts are behind the intercooler. Too much fin density means all parts behind the intercooler will be blocked. The worst case would be, you’ve solved the problem of high intake air temperatures, but the engine coolant temperature climbs. High performance manufacturers note all these factors and develop the most suitable structure of outside core design. Low Density Core // // // High Density Core Also notice the staggered offset fins for a larger contact area on the intercooler on the right The INSIDE CORE is responsible for heat exchange with the hot charged air and also need to handle the additional air flow which is running through the intake system. Care needs to be taken when deciding the internal fin density. A high internal fin density gives great cooling performance but with a high pressure drop. The pressure drop of the cooling system should not be adversely affected by an aftermarket intercooler. Less pressure drop reduces the mechanical load on the turbocharger (stability & life time for the turbo). High performance intercooler manufacturers find the best balance between high cooling performance, reduced pressure drop and design their intercooler cores specifically for each vehicle. The right ENTANK DESIGN is another key consideration when you are looking for the best intercooler for your car. It is easy to see the difference between a good and a bad aftermarket intercooler. There are different approaches, some manufacturers use sheet metal end tanks and others use cast aluminium end tanks. At flow velocities of around 100 m/s it makes no sense to let the air flow straight in to a wall. This causes unwanted turbulence inside the end tank and higher pressure drop. Furthermore, uniform filling of the intercooler is critical for optimum performance. To aid this, some manufacturers add internal air guides. Size & Fitment The size of an intercooler is not always proof of better cooling. There is an old adage which says "Power is nothing without control". This can be applied to bigger intercoolers. If you construct a bigger intercooler without working with internal air guide systems and flow optimized end tanks, the air will not flow through the whole system and choosing a bigger intercooler makes no sense because the intercooler is not being used effectively. Although the size of the intercooler is changing, the installation should not require mutilation of the vehicle. To avoid nasty surprises you should always look at the installation instructions (if available). Additionally you can seek reviews from neutral and professional sources. I know sometimes it is quite difficult to recognize those sources. Here is my advice on how to pick the right intercooler for you Don’t get an intercooler because someone on the forum says it’s cheap, it fits and they feel it is doing a great job. Ask for logs. Check if the manufacturer invests time and money in development/engineering, to get the latest technology in your intercooler. The needs of the cars and tuning them changes all the time. Don’t get an intercooler just because people say it is the best. Get an intercooler because professional tuners say it the best. The best intercooler on a fully bolt on car with upgraded turbo might not be the best intercooler for a stock car with stage 1 tune. Start by thinking ahead in terms of modifications that you will eventually add on your car. If you plan on going fully bolt on in 1-2 years, get an intercooler that suits the fully bolt on application. Bigger is not always better. If you do not plan on getting stage 2 turbo, don’t get an intercooler built for stage 2 applications. You want an intercooler that provides the best cooling with the minimum pressure drop. If the right intercooler is over your budget, wait until you have enough funds or try saving on other mods so you can get the right intercooler. Ebay Notes Some justify getting an ebay intercooler for the following reasons:
As mentioned above, getting a bigger intercooler does not always mean you are getting better performance. You might get better IAT than stock, but your pressure drop will be higher and so the couple hundred dollars you spent on a cheap solution did not help. If you are not going to pick a brand that takes into consideration everything mentioned above, you are better off keeping your stock intercooler. As i said earlier, dont get the biggest most expensive FMIC if your car is a daily driver with stage 1 tune. Talk to vendors / tuners, tell them your HP goals and mods + your budget. They will recommend an FMIC that suits your needs.
01-18-2018, 11:31 AM | #2 |
24190
Rep 190,802
SteveInfante604.00 |
01-18-2018, 01:55 PM | #3 |
4516
Rep 8,942
Hey, Mike. Really happy with the Active Autowerke intercooler you sold me had it installed last week.
Sent you guys an email not sure if it was you or Marc who responded - but as you're posting info especially in forum sections with some convertible drivers, might be good to point out that the install is much more involved vs coupe / sedan. Still a great idea to add an IC and 2 hours of labor at a shop to get done, but none of the DIY videos point out how much more involved it is. Folks should know what they're getting into.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
01-18-2018, 07:45 PM | #4 | |
313
Rep 525
01-18-2018, 09:58 PM | #5 | ||
24190
Rep 190,802
I think it would be a great idea to post a thread documenting the extra steps that need to be taken when installing an FMIC on a convertible
01-19-2018, 09:23 AM | #6 |
4516
Rep 8,942
Not sure it merits an entire thread, but happy to start a new one if helpful so let me know. In essence install for coupe is remove belly pan, unclip IC, unbolt IC, drop out. Reverse with new one for install.
On a convertible, you can't get past remove belly pan without doing a lot more work. The car has a lot of extra cross bracing underneath, which runs the entire length of the car. This is to make up for losing the top and torsional rigidity. Anyway once you remove belly pan you will notice that this massive brace is directly under the IC, where you need to drop it out. Again it runs side to side and front to back. So you need to remove all the cover plates on the bottom, then drop this bracing. Then once that is done in front of the IC there are more braces - like behind the kidney grilles but on the lower section. So muscling the new one into place is much more challenging as there isn't as much room to work. To do at home you need to get the entire car up in the air not just the front end on ramps. Then if you are laying under the car you're basically unbolting this giant heavy bracing that's on top of you. Non of this is impossible, it's just a lot more work than the coupe. And for something that involved I was more than happy to pay the dealer to do it. Sorry I don't have any pics but my install went something like: 1. remove belly pan 2. yell fuck, throw my screwdriver, scare the dog 3. call Matt @ Thomson and tell him that once again he was right, I was wrong, and I couldn't do this myself 4. drop car off, hydroplane loaner X5, pick car up
2022 Macan S
01-19-2018, 03:59 PM | #7 |
4516
Rep 8,942
Post #67 in this thread has some good photos. Not an F23 but close enough to give you an idea of what's going on under there. The bracing we have is different but obstructs IC the same way this one does.
http://f30.bimmerpost.com/forums/sho...1234698&page=4
2022 Macan S
04-26-2018, 08:23 AM | #8 |
12
Rep 25
I've had my 2014 (CPO) 228i MSport Coupe for less than a year, and I just "discovered" this discussion. Great explanations by Mike and BEM-S4! As this is my first turbocharged car, I need some basic information: are our intercoolers air cooled or water cooled? For a non-modified car, should I upgrade? If so, what advantages would I get: power, MPG, longevity of engine, etc.? What about warranty issues? A few days ago I came across a dump truck that was dropping something (pebbles?) that hit my car, should I protect the intercooler with mesh? During fall I got a lot of leaves all over the place down there so I used a vacuum cleaner, any other cleaning technique to avoid dirt blocking the fins? Thanks!
04-26-2018, 11:35 AM | #9 | |
24190
Rep 190,802
The intercooler is air cooled You can change it on a stock car but it is not needed Tune should always be your first mod No warranty issue as the intercooler does not put any extra pressure on any of the car's components
05-25-2018, 11:41 AM | #10 |
24190
Rep 190,802
07-05-2018, 10:45 AM | #11 |
24190
Rep 190,802
07-15-2018, 07:06 AM | #12 |
im a car
736
Rep 1,117
Drives: 220i M Sport | 520i M Sport
what kind of IC would be ideal for a stock turbo, stage 2 tune w/catted downpipe N20? No track, road use only
'14 220i M Sport | AW/CR | PUR Wheels RS07 19" | KW V1 | MTC Design F2X Kit [CF] | Stage 1 ECU Tune | Eventuri CF Intake | Manhart Race Exhaust/Resonator Delete | ER HFC Downpipe | F8X LCA + TS | M Style Grilles | Gloss Black Roof | Custom Steering Wheel | Autotecknic Competition Shift Paddles [YMB] Instagram: @icyj95 | FB Last edited by Icy J; 07-15-2018 at 07:30 AM.. |
Pillz1737.50 |
07-15-2018, 03:08 PM | #13 |
Rep 4
07-16-2018, 09:46 AM | #14 | ||
24190
Rep 190,802
I would make the decision based on how hot it gets in your area
07-16-2018, 09:55 PM | #16 |
24190
Rep 190,802
08-22-2018, 10:31 AM | #18 |
19
Rep 80
If I can piggyback off this, looking at intercoolers for a 235, plan to be doing a JB4 and exhaust at the same time, but will likely not go much farther than that mod-wise. Most use would be on the hottern' hell highways of Houston. Would something like the CSF be overkill in this case?
08-23-2018, 12:46 AM | #19 | |
24190
Rep 190,802
03-14-2019, 01:04 PM | #20 |
Rep 1
ebay intercoolers
I just recently bought an ebay intercooler and the brand name is ETL Performance. and im actually suprised by how well made everything is. all clamps and hose ETC.
03-29-2019, 11:55 PM | #21 |
75
Rep 323
Drives: 2013 BMW F30 N55 335ix 6mt
need intercooler to finish FBO. I am eventually going ps2. I am between er, atm, wagner evo 2 comp.
which will be best for whp? also is there alot of turbo lag with er on stock turbo before I can get ps2 |
03-30-2019, 08:37 AM | #22 | |
24190
Rep 190,802
The intercooler will not cause any lag on an upgraded turbo application. All three are really good options, do you plan on tracking the car?
