codes
03-01-2016, 12:24 AM | #1 |
4542
Rep 11,903
codes
Wondering if anyone can interpret these codes and help explain the surging problem
These from the MHD code reader 3100 boost pressure control, deactivation 2C7C Lamba probe behind cat converter 2, signal 2ABC Changing pressure sensor, electrical Shadow codes 2FA3 Code missing 2FCA Unknown code 2FDA Unknown code 2FDB Unknown code 29F4 Catalytic converter conversion 29F5 Catalytic converter conversion 2 Running catless DPs |
03-01-2016, 12:35 AM | #2 |
1495
Rep 3,148
2abc is the code when you max out the map sensor.
Also have a secondary o2 sensor that's possibly faulty Mhd is a poor code reader, really need to use INPA, as error codes have more than just a code, they have mileage and ambient conditions which help you in your diagnosis.
03-01-2016, 12:47 AM | #3 | |
4542
Rep 11,903
I thought it could handle up to 25 psi? Is the secondary cat O2 sensor important to engine management? I thought it was only the precats that played a signifcant role after going catless? |
03-01-2016, 12:52 AM | #4 | |
1495
Rep 3,148
Secondary o2s don't do much but if they're faulty they cause error codes. I had an exhaust leak at the downpipe->exhaust flange and got secondary o2 codes.
03-01-2016, 02:12 AM | #5 | |
4542
Rep 11,903
Ill pop around one night after work and see if we can plug it into your magic lappy lel |
