02-29-2016, 02:18 PM | #1 |
18853
Rep 14,140
Drives: G82 M4C X-Drive
OEM M Performance Rear Diffuser not for 340i?
I'm looking to get the OEM M Performance Rear Diffuser for my 340i but both shopbmwusa.com and GetBMWparts.com do not show they are compatible with the 340i. I know that the 328i diffuser is for single exhaust, and the 335i diffuser is for dual exhaust, so I wanted to order that one, but will it fit the 340i exhaust?
I was also thinking of getting the RW Carbon CF diffuser, which says it fits the 340i, but I'd rather not deal with fitment issues. They state you need to remove the bumper to install, which I hear isn't the case for the OEM diffuser. edit: why is the RW CARBON website censored out? Bad reputation? The Ebay Advanation looks promising, made of PP and that lists as being 340i compatible. If anyone has any experience with the Advanation, feedback is appreciated. Do I need to remove the bumper?
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 Last edited by jmg; 02-29-2016 at 02:25 PM.. |
02-29-2016, 04:05 PM | #2 |
514
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
The 335i M Performance Diffuser should fit the 340i w/ M Sport... if it doesn't then I guess I got a paperweight sitting in my bedroom right now
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
02-29-2016, 04:39 PM | #3 |
18853
Rep 14,140
Okay thanks. I think I will have the dealer install it just to be sure.
Well, I guess you could move it to your garage, problem solved! j/p
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
02-29-2016, 08:16 PM | #4 |
2812
Rep 5,316
Drives: G80 M3 6MT
Don't waste your money. It takes like 5 minutes to install yourself.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
03-03-2016, 01:17 PM | #5 |
18853
Rep 14,140
You underestimate my incompetency with a drill.
03-03-2016, 06:06 PM | #6 |
Rep 29
03-03-2016, 09:54 PM | #7 |
2812
Rep 5,316
Drives: G80 M3 6MT
You don't need a drill. You need a small socket set and the basic knowledge of right-tighty, lefty-loosey.
Scott, Partner
03-15-2017, 12:24 PM | #8 |
57
Rep 173
Sorry to bump an old thread but I figured it better than starting a new on the same topic. I'm also in the market for the OEM M Performance Rear Diffuser on my new 2017 340 M Sport. I can only seem to find the diffuser for the 335 but I'm making a big assumption that it does in fact fit the 340 M Sport frame.
I haven't purchased anything yet. Originally I was going to go with the RW version, but I can find OEM for about $100 more. Not to mention, I read that you have to remove the damn bumper to install the RW version which seems a bit excessive. I called my body shop and they quoted me a god awful $400 estimate in labor alone which is ridiculous. I'd rather buy the OEM for $100 more and install myself. Do you need a lift to install the OEM? Sorry for the loaded post but shopping for upgrades and install has turned out to be a huge pain in the ass. Also looking into CF mirror caps, which I imagine should be a seemingly simple install. Any insight you guys have would be appreciated. I could not stand to drop $770 for the mirror caps through the dealer.... |
03-15-2017, 12:30 PM | #9 | |
448
Rep 1,056
03-15-2017, 12:35 PM | #10 |
57
Rep 173
I'm thinking that will be my likely course of action as well. Seeing it on ebay now for $400 but may wait it out a little longer to see if the price drops.
03-15-2017, 01:36 PM | #11 |
514
Rep 1,055
F30 Diffuser DIY Install
I installed a used (2012, I think) F30 335i M Performance diffuser on my 340i without issues and didn't have to remove the bumper. You just have to squeeze your hands behind the diffuser after you've removed the bolts to access some of the tabs which hold it to the bumper.
I took these pics to post a how to because no one seemed to have shared proper pics in any of the threads i came across... but never got around to it so I'll post em here 1. Remove the 7 bolts from underneath the existing diffuser (I don't remember the size but I believe they were 8mm) 2. Get your hand or a screw driver behind the diffuser from under the bumper to push 8 tabs out of the slots on the bumper (also see 3rd pic below for reference). You should be able to pull down the diffuser to access the tabs now that the bolts have been removed. Here's what the tabs look like when attached to the bumper: 3. Once all the tabs are out of the slots, you can pull the diffuser off easily. Here's a side-by-side comparison as well as the tab locations on the bumper. I've also noted the bolt locations on the diffuser; you can see the bottom of the diffusers in this view: 4. To install the new diffuser, you just need to do everything backwards. IIRC, I started with attaching the tabs in the middle of the bumper and worked outwards. Then screw the original bolts back in from underneath and you're done. Good Luck!
03-15-2017, 02:57 PM | #13 |
18853
Rep 14,140
Excellent write-up!
03-16-2017, 12:23 PM | #14 |
1567
Rep 4,109
Drives: BMW M3
Very nice write-up indeed!
Charles
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
11-07-2017, 01:57 AM | #15 |
65
Rep 240
Gentlemen,
I hate to revive an old thread but I just had to chime in after attempting to install an eBay F30 diffuser onto my 2017 340ix. The seller's fitment guide clearly stated (or perhaps assumed) that it would fit a 2017 model with the M Sport rear bumper. BUT, it didn't! I bought from a seller who had sold nearly 200 of them and these were advertised as the "Taiwanese", which had superior fitment and build vs Chinese ones. The cutouts for the slots/tabs were off by at least 1/4". The center "dip" section where the fins are located was about 3/8 of an inch NARROWER on the diffuser than on the bumper. And when I held up the diffuser to the OEM flat piece to measure end to end. It was shorter by about 3/8". There was a reason why the official BMW sites only list the 335i and the 328i. Needless to say, I sent my diffuser back to the seller who gave me a full refund. eBay also refunded me the return shipping so it was just time lost. So, those with the 340i modes from 2017 need to beware of this potential issue. I noticed that MOST sellers do not list the 2017s as compatible. My guess is that those listing are unaware of this issue. I e-mailed my seller and never got a response. Every YT video show an easy fit once you pop off the reflectors, which I did. But non of those videos are of 2017 340i models. If someone has successfully ordered and fitted a non OEM plastic rear diffuser onto their 2017 340ix, please let me know. I'm still in the market for one. Last edited by dsc888; 11-07-2017 at 02:02 AM.. |
11-07-2017, 04:30 PM | #16 |
Rep 15
I purchased the RW Carbon version for my 440 (sorry not a 340ix) but it's still a 2017 and the fit was perfect. Installed in less than 15 minutes.
If someone has successfully ordered and fitted a non OEM plastic rear diffuser onto their 2017 340ix, please let me know. I'm still in the market for one.[/QUOTE]
2017-440i, Mineral Grey, Black Leather, 6 M/T, 21C/ZCW/ZDA/ZDB/ZTP/ZTR/ZMP/Apple Car Play/Clear bra/Tint/black M kidneys/RW Carbon rear diffuser/black chrome exhaust tips/ PS4s wrapped on 763 rep wheels
11-08-2017, 06:04 AM | #17 |
205
Rep 555
I ordered and installed the one from advanation on ebay. No issues w/ fitment nor installation.
Boston CCA 383036
'20 M340i '18 MB GLS550 '07 4Runner V8 Limited 4WD |
11-08-2017, 09:39 AM | #19 |
65
Rep 240
Thanks, Das440i and skw. That's great news! I was beyond shocked when mine wouldn't fit. I've installed bodykits before so it's definitely not from lack of experience. Maybe I had a bd unit but I highly doubt it. Maybe I will take a 2nd try and see if I have better luck this time from another vendor. I'm just nervous that there might have been a silent running change at BMW for 2017s.
11-08-2017, 09:45 AM | #20 | |
65
Rep 240
https://www.ebay.com/itm/3-Series-F3...-/172873205222 |
11-08-2017, 10:39 AM | #21 | |
205
Rep 555
http://f30.bimmerpost.com/forums/sho...9&postcount=19
Boston CCA 383036
