No power (no boost?)
02-27-2016, 01:46 AM | #1 |
62
Rep 460
Hi everyone,
I NEED HELP! I'm having some issues with my 335i. My father drove my car for the past few months and called one day to say that the engine check light went on when he was accelerating and made a sharp lane change. The engine check light has not come back since. However, upon getting the car back I noticed that it lacks significant power (feels like it is limp mode). I used Bavarian Technic and saw the 30FF shadow code come twice during the time my father had the car. I also used JB4 to log and there is 0 boost. Also, when starting the car, a ton of what seems like oil spits out from the back (see image). Additionally, I had the oil changed this past Saturday at 6K miles and the mechanic said it was very dirty. No codes are being thrown. Things done to the car recently: 1. Mechanic adjusted the charge pipe and the downpipes because it was rubbing just before my father took the car. 2. new fuel injector about 4k miles ago 3. new spark plugs about 4k miles ago 4. Vacuum lines and turbos were replaced by BMW 1 year ago. What could it be? How bad is it? Could it be a blown gasket that is causing no boost and oil from being spit out from exhaust at start? No CEL but I have a BMS backend flash and so may affect code triggers?
2008 E90 335i: JB4 G5 ISO | BMS Pump Gas Backend Flash | ER Charge Pipe | n54Tuning DPs | ETS FMIC
02-29-2016, 04:58 AM | #3 |
547
Rep 2,590
You need to find the root code. The 30ff is just a safety features to cut boost till the main problem is resolved. Stop pushing the car at this point, check all turbo connections at the ic and chargepipe. If it truly is oil you're seeing out of the tailpipe you would be getting more codes than 30ff.
02-29-2016, 09:58 AM | #4 | |
62
Rep 460
03-01-2016, 11:45 PM | #5 |
62
Rep 460
Turns out that it was the JB4 interfering with the electrical signal that controls the vacuum that moves the turbo wastegate actuators. When I removed the JB4 the boost came back. I read another thread where they had the same problem and they fixed the problem by crossing the wastegate wires in the harness. Does anyone know what crossing the wastegate wires means?
03-12-2016, 02:33 PM | #6 |
62
Rep 460
Turns out it was the JB4 boost transistor that needed to be upgraded / replaced.
03-12-2016, 04:13 PM | #7 |
Rep 117
can you give me some more info on that? I tried to google jb4 boost transistor but got 3 links to burger tuning sales for jb4s for different applications, 4th was this thread, then some stuff about the DME mosftets. bought a used jb4 that all the cool little features work but it builds 0 boost, and based on the deformed plastic case and slightly discolored board you can tell something has gotten hot before.
might be worth a shot before I just give up and toss it.
07 A/W 335i 6AT/JB4/race BEF/FSB METH CM5/VRSF DP/DCI
03-12-2016, 05:23 PM | #8 |
Rep 117
ok, didnt find anything related to the jb4 transistor problem itself but googling in geeral I found the part, and found how to test it with my DMM, and found a replacement.
if this works I owe you for setting off the litle light bulb in my head!
03-12-2016, 09:13 PM | #10 |
Rep 117
if its the first you heard of the issue, then its probably not a common issue... and its not necessarily my problem and I got mine used so who knows what its been through as far as previous (possibly faulty) installations.
my other one is used as well and I havent had a problem for 5 months with it. and 2 friends bought theirs used as well and one has at least a year on it and another even more than that.
03-27-2016, 02:44 PM | #11 | |
62
Rep 460
03-30-2016, 09:03 PM | #12 |
Rep 117
no big deal, I just sent it in the other day. I am paying for it but its a very reasonable price and since I bought it used I couldn't expect them to do it for free.
