02-24-2016, 01:38 PM | #1 |
Supreme Allied Commander
3837
Rep 54,348
Drives: F80 M3
Stoptech F2x F3X Stainless Steel Brake Line Kit
Stainless Steel Brake Lines
SportStop stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. This provides a quicker pedal response, and allows the driver to maintain consistent brake pressure and precision brake modulation. SportStop brake lines consist of a TeflonŽ inner line that is covered with a layer of stainless steel woven braid. The Teflon tube is very resistant to expansion under pressure and will not degrade from exposure to brake fluid. The stainless steel braid provides support for the Teflon and the weave is extremely durable against incidental impact and abrasion. SportStop brake lines feature a Clear Abrasion Resistant Cover for maximum protection against chaffing. For vehicle with M Sport Brake Package(4 piston front and 2 piston rear) ***Set of four lines for all corners of the vehicle*** $154 Order here: http://www.hpashop.com/Stoptech-F2x-...x-SS-Lines.htm Last edited by HP Autosport; 04-05-2022 at 08:56 PM.. |
01-16-2017, 04:04 PM | #17 |
3837
Rep 54,348
Drives: F80 M3
If you track your car, you should serious consider this upgrade.
06-07-2017, 04:18 PM | #22 |
3837
Rep 54,348
Drives: F80 M3
