02-23-2016, 12:22 PM | #1 |
14
Rep 143
ACM P3 Cars Vent Gauge Pod
ACM P3 Cars Vent Gauge for the F8X M3/M4. Brand new never used still sealed. Details: Connect with your car in an entirely new way. Why settle for just a boost gauge? Sporting features available in products 3x the price, this is a swiss army knife of performance data, with design and integration that won't spoil the clean lines of your interior. Specifically designed to support the 2012+ F3X BMW 3 Series and 4 Series platforms and now ready to be installed in your new M3/ M4 Plug and Play install Quick plug and play install with zero cutting required. All power and ground connections come directly from the low profile concealed diagnostics port connector. Boost/Vacuum Display High resolution boost/vacuum display showing actual manifold boost, Read Boost/Vaccum via diag port directly, no tap required. Multiple Gauge Displays Boost/Vac, Coolant Temp, Intake Air Temp, Exhaust Gas Temp, Throttle Plate, Speed, RPM with Shift-light, Battery voltage and more! Peak Recall & Run Record Recall the peak value from any mode, or record and playback 15 seconds of data from the current mode. Temperature peaks recorded in the background. Universal Aux Inputs Includes additional inputs to optionally connect any 0-5v sensor with universal settings for display ranges and bargraph displays from -999 and 9999 max values. On the Fly Configuration Menu Lockout/Display off mode, English(PSI, F, MPH) or Metric(BAR, C, KPH) selection, Adjustable boost display resolution, Ambient Calibration for boost sensor and more! ACM Exclusive Features:•Air/Fuel Ratio with no additional wiring •60-0 Braking Timer •100-0 Braking Timer •0-100 Acceleration Timer •60-130 Acceleration Timer, •Signature ACM Faceplate |
03-13-2016, 10:31 AM | #2 | |
67
Rep 358
