What is happening here ?? Throttle/engine lag ??? I am totally lost !
02-23-2016, 12:01 PM | #1 |
26
Rep 84
Hey,
I hope you guys have some insights in this matter, because i really, really can't wrap my head around it. I regulary do some logging. A week ago i noticed some weird "lag" Everytime i mashed the throttle , there is a really small delay. So i went to the logs, So i thought there was a boost leak. But boost building is working as intended. WG functionality is normal, and i am hitting peak boost everytime. Then i started to look at the acceleration pedal/throttle body behaviour. Everything seems normal, Throttle body is a bit behind accel pedal maybe , but nothing to weird. Then i noticed that when I go WOT , the moment there is no boost building, there is actually no RPM increase either... Obviously no rpm increase... no boost... thus "lag" But the strange thing is, at that time throttle body is wide open @ 80%. Does someone have some experience or thought about this ? This is a Log where you can see the flatline at the start of WOT: http://datazap.me/u/odanbe/mhd-stage...&solo=4&mark=9 And this is zoomed in on that specific part...: http://datazap.me/u/odanbe/mhd-stage...om=4-14&mark=9 |
02-24-2016, 02:00 PM | #4 |
457
Rep 539
I have similar symptoms as well, replaced coils, injectors, plugs a few months ago. Boost builds to peak, WG cycle is normal.. I know I need a walnut blast done but that doesn't seem like it would affect the car this drastically. It's like no boost, no boost then bam! the car rockets off. The cobb shows full boost the entire time but never over boosts.
02-24-2016, 02:01 PM | #5 |
BimmerPost Supporting Vendor
24298
Rep 190,975
+1 for walnut blast
02-25-2016, 03:29 AM | #6 |
26
Rep 84
Ok,
then i might just shedule a walnutshell blast... How come clogged / dirty inlet ports will cause this ? Had an accident this week, so I might as well do everything together |
02-25-2016, 03:42 AM | #7 |
75
Rep 853
02-25-2016, 04:26 AM | #8 |
23
Rep 85
I've been getting weird throttle behavior as well. Enough so that I think it's either the adaptations from driving too slow and throwing off calculated values?? or my throttle position sensor is going bad. It is hit or miss each day as to which way it behaves but essentially some days it's fine and other days it rockets off to exactly the same rpm through gear shifts. In a weird way.
02-25-2016, 10:37 PM | #11 |
26
Rep 84
02-26-2016, 08:07 AM | #12 |
Resident old fart
146
Rep 575
Just a random comment, are you making sure to turn traction control all the way off before logging? If you have not, the ECU will chop the throttle when it detects wheel spin and cause exactly what we are seeing in your logs.
The only other thing that I see is that your fuel trims indicate that you are running very rich and are doing their best to lean out the car. I can see where your A/F ratio was in the 11's & 12's. |
02-26-2016, 10:11 AM | #13 | |
104
Rep 1,059
02-26-2016, 05:45 PM | #14 | |
26
Rep 84
Don't know what you are talking about AFR wise. But AFR is fine to me Starts at normal 14 ish at low revs and then more rich near top end... to more lean you run near the top end , the higher your temps get in the manifold/turbo's... |
02-26-2016, 06:55 PM | #15 |
Resident old fart
146
Rep 575
Take a look at your short term fuel trims, the ECU is pulling a lot of fuel out of the mix, I can see -19% near the end of the boost runs.
Then look at the A/F ratio under boost and you will see where it is consistently in the 11's. I cannot see what is causing the throttle closures, but the rich mixture is the result. The throttle is closing and restricting the air flow into the engine while the injectors are adding fuel for a larger amount of air. The resulting mix is rich and the ECU pulls fuel to lean it back out. Log more parameters and see if you can find the reason for the throttle closures. Last edited by Velocity26; 02-26-2016 at 07:23 PM.. |
02-28-2016, 05:03 AM | #16 | |
26
Rep 84
trying to solve that with making the throttle plate less sensitive, because it was set really sensitive. it is only Stft 1 that is so high , i presume that is bank 1 ? maybe it is carbon build up, not allowing the valve so seal correctly ? what could be a possible other cause ? |
02-28-2016, 03:08 PM | #18 |
The Replacement for Displacement
22
Rep 126
I had this issue before I flashed my car. It seemed like throttle input lag where when I would drive around normal with it, the car would get use to it. Then when I go WOT it would take a moment to realize I wanted to go.
