misfire goes away with restart engine
02-18-2016, 08:40 PM | #1 |
16
Rep 71
Hi guys
I have a misfire with SES light that comes on. The misfire only happens on cold starts. The car starts shaking, does not accelerate, and throws an SES. However when I pull over and turn off the car and turn it back on, the misfire is gone instantly (and so is the SES). This has happened 3 times now. I already changed the spark plugs, no fix so i'm down to coils or injectors. Seems electrical but not sure coils do this? 09 n54 335i 40k miles Thanks Last edited by jc2078; 02-18-2016 at 08:45 PM.. |
02-18-2016, 09:47 PM | #2 |
52
Rep 278
If x amount of misfires in y amount of time, that car will throw an SES and turn off that cylinder. Restarting and it going away is normal. But there should be misfire codes stored letting you know what cylinder the issues are on.
02-18-2016, 11:02 PM | #3 |
252
Rep 1,869
First thing is first, read the stickies on this subsection. Also usually a Google search will bring up every thing you need to know about the codes/symptoms and more.
Since you changed your plugs, usually the next culprit are the coils. But since you misfire on cold starts only, sounds like a leaky injector. Pull the codes check which cyl., check that plug for fouling.
07 335xi (2007-2010)
08 Legacy Spec B (08-) 09 335i (2010-) 15 X5 xdrive 35i (2015-) 17 Forester XT (2016-) |
02-18-2016, 11:36 PM | #4 |
530
Rep 2,084
What codes are you getting? Check the code and see which cylinder it is, then swap that cylinder's coil with another cylinder. Wait until it happens again, then check the code and see if the code switched cylinders. If the code follows the coil then it's the coil. If not then it's probably the injector.
2013 135is DCT Carbon Black Metallic |
02-19-2016, 11:36 AM | #6 |
232
Rep 723
I'm sorry but no one would be able to help w/o codes. If you dont have the means to read codes, then take it to the dealer. Codes will be stored in the ECU. I assume at 40K you still have factory warranty.
02-20-2016, 03:10 PM | #14 |
69
Rep 310
Drives: 2007 BMW 335i M-Sport E90
I started getting misfires when i WOT in 3rd gear. Coils and spark plugs already replaced. I guess injector is next?
Cobb ap tune Last edited by =C=; 02-20-2016 at 03:27 PM.. |
02-20-2016, 05:45 PM | #17 |
380
Rep 1,497
Sounds like u reset the throttle adoptions as well. Let the car learn those before driving. Let it idle for a few mins and drive slowely around
02-24-2016, 03:32 PM | #19 |
530
Rep 2,084
After resetting adaptations you need to clear codes and/or let it sit for a bit otherwise you'll get the surging idle issue.
03-22-2016, 07:54 AM | #21 |
16
Rep 71
Codes came back (cylinder 1-3 misfire) same as above. Any chance this is the low fuel pressure sensor since I have code 29f3 too? I have had that code for a year tho
03-22-2016, 08:05 AM | #22 |
18
Rep 283
I have the 293F Code as well.
It's most likely the low fuel pressure sensor. I have ordered the part and will let you know if this solves my problem, my symptoms are exactly like yours.
335i Coupe 6MT Montego Blue
