Limp Mode..what's causing it?
03-02-2008, 11:41 AM | #1 |
54
Rep 1,677
So I am diving back from Cotillion(some formal dance crap) with some friends last night and this tough shit in a 328 wants to gun it. So I gun it and once I get into the 3k RPM range, I get that feeling that I've hit a dog or something. This feeling has been experienced before but with no CEL/limp and I just thought I was going crazy. So I limp all the way back to my friends place. The car was stuttering all the way there. I couldn't stop on the bridge or anywhere to restart the ar as he lives off a fairly busy street. I only drove about 1/2 a mile limping. The car was stuttering and shaking really violently while idling and driving, but worst at idle. I got to my friends place and whipped out the Code Reader and I don't know how to use it that well as I never had to in the past. I assume I did it correctly as the limp mode and SES light went away. When I plugged it in w/ ignition on it said LAUNCH 1 2 3.....4 5 6 then E. No code or anything showed and it would then just repeat what it just said. I started the car later to go to my girlfriend's house and it drove fine the like 10 mile drive back in which I gave it some gas and went through a couple of gears to see if it would repeat.
So I wake up this morning and drive home from my girlfriend's house and a I come down my street I give it light acceleration and hit about 3k RPMs and limp again. So I stop and restart the car w/o using the code reader. No SES light but the car is still shaking like a bucking bronco. About 30 seconds in, the Engine malfunction, power decreased comes on on iDrive again. So I shut down and use the code reader again and same thing as last time with the E. Then I restart and its still shaking a little but not as bad, so I drive ome nd park in the driveway and it kept on bucking. I plan to go out once the engine bay cools and check my v2 connections, especially the power. Before these limp modes the car was giving a couple of shakes here and there and I thought I had a bad tank of gas. So here's the question. What is causing it? I figure it is either a bad connection between one of the Procede wires and the ECU, the power line on the v2, a horribly bad tank of gas, or my fuel pump. Any educated guesses out there?
Legal Disclaimer: Anything I or anyone else says about my vehicle on this website(e90post.com or any affiliated or nonaffiliated sites), pertaining to modifications, is only to gain acceptance from my/our peers, and does not actually represent anything actually existing on my car, and thus, cannot be held against me in any issues, i.e. warranty claims, that may arise.
03-02-2008, 11:51 AM | #3 |
54
Rep 1,677
Maybe. I should be able to eliminate the Procede when I open it up and check the connections.
Thing is, I got the best Procede guy down here who's even friends with shiv to install it for me and he used heatshrink. Therefore I don't believe it is the wiring, but am going to check to make sure anyways.
03-02-2008, 11:53 AM | #4 |
*Rollin 3rd*
106
Rep 1,232
+1 sounds like a fuel pump
same thing with my car...turned out to be a bad solenoid but i DID NOT have idle shakes for the reader to pull the code it has to have the SES light Limp mode throws nothing for your reader to pick up Edit: another thing you can do, is to remove the procede and see if limp occurs while car is stock |
03-02-2008, 12:05 PM | #5 | |
54
Rep 1,677
Would it really be the fuel pump if it is only occuring around 3k RPMs? Once I hit limp it sure as hell feels like a bad fuel pump, but other than that it would give off one or two shakes a day, and nothing as extreme as that. I haven't had any signs of the fuel pump going out and now it just goes? I was expecting more of a show before it died . Also, would the car be OK to drive until I could bring it in? I haven't read of anyone's car completely dying on the road. Is this a possibility, though?
03-02-2008, 12:18 PM | #6 | |
*Rollin 3rd*
106
Rep 1,232
I would take it off just to test how it runs on stock to know whether it's something wrong with the car...or tune/connections how many miles do you have on your car? and about driving it.... if it shakes randomly with out warning...i wouldn't risk |
03-02-2008, 12:31 PM | #7 |
54
Rep 1,677
I have about 4800 miles on the car.
I guess I will try the bypass plugs for the week. I need the car to get to school. It doesn't shake bad until I hit limp mode.
03-02-2008, 12:41 PM | #9 |
54
Rep 1,677
Will do . I was just taking suggestions. At least I have it narrowed down as to what it could be.
03-02-2008, 12:47 PM | #10 |
441
Rep 18,331
Check the connection of the power...Did he heatshrink the power line...That connection on alot of people causes problems...Thats the wires corresponding to the green plug in the ecu..If there is a slight connectivity problem, it will cause the car to buckle and go into limp also...
03-02-2008, 12:49 PM | #11 | |
*Rollin 3rd*
106
Rep 1,232
if it is a fuel pump you can take it in and get a loaner just when you take it in don't forget about the bypassed solenoid |
03-02-2008, 12:52 PM | #12 |
441
Rep 18,331
03-02-2008, 12:55 PM | #14 |
441
Rep 18,331
You probably would know better than me than!! but this is what he wrote
I plan to go out once the engine bay cools and check my v2 connections, especially the power. Before these limp modes the car was giving a couple of shakes here and there and I thought I had a bad tank of gas. |
03-02-2008, 01:41 PM | #15 | |
54
Rep 1,677
03-02-2008, 01:42 PM | #16 |
54
Rep 1,677
And yes, I have v2 .
03-02-2008, 02:25 PM | #17 |
54
Rep 1,677
Anyone have any ideas? I am probably going to postpone getting gas until later in the week.
03-02-2008, 02:35 PM | #18 |
441
Rep 18,331
Well thats the problem, you need to see underneath that green plug how the wires are...Its very tight when u place the wires back...In my case when I put the wires back the wires kinked and loss connectivity because it was bent...You need to check underneath that wire to see the condition of it after the green plug was reinstalled!
03-02-2008, 02:39 PM | #19 | |
54
Rep 1,677
03-02-2008, 02:44 PM | #20 | |
Rep 56
03-02-2008, 02:44 PM | #21 | |
441
Rep 18,331
Just remove the green plug and see the wires underneath what they look like...is it kinked or bent! Thats what happen to me...I checked all my wires but not the wires underneath the green plug...Well long story short started to de-install the Procede and the last wires was the green plug wires...Too out the plug to see the power wire connection to the orange wire was kinked to the point that there was sometimes connection and sometimes none!!! |
03-02-2008, 02:50 PM | #22 |
54
Rep 1,677
Did it go away when you restarted the car and only happen at certain times? Or was it shaking all the time? My problem is intermittent so I can't be sure whether or not it is the pump.
