N53 catch can
02-12-2016, 08:12 AM | #1 |
102
Rep 681
N53 catch can
Hi
Has anyone fitted an oil catch can to their n53 and if so can you give any advice please.. how to fit it etc, which make did you go for.. Thanks Mike |
02-12-2016, 11:34 AM | #2 |
622
Rep 3,198
Drives: E92 325i MSport Coupe
Yes I did. Got one of these from the USofA:
http://www.saikoumichi.com/ Plumbed it in to the line taking oil and vapour from the crankcase breather to the inlet side. Incidentally I also partially blocked the EGR line to minimise exhaust cr*p getting into the inlet side.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
02-12-2016, 12:04 PM | #3 |
622
Rep 3,198
Pics showing installation below. As my car has electric steering I was able to mount the OCC on the bracket where the power steering reservoir usually sits.
02-13-2016, 02:14 AM | #5 |
622
Rep 3,198
I reckon it catches about 0.5 litres every 16,000 miles, so for me once a year is fine.
02-13-2016, 04:46 AM | #6 |
Rep 442
Why have you fitted a catch can? I thought these where used for turbo/supercharged cars, it's only because I've never seen one fitted to a na engine.
Looks a tidy installation nice job |
02-13-2016, 04:50 AM | #7 |
622
Rep 3,198
To help reduce carbon build-up on the backs of the inlet valves. The N53 is direct injection...
05-08-2016, 03:01 AM | #8 | |
Rep 113
If so was it much of a job? |
05-09-2016, 07:15 AM | #9 | |
37
Rep 278
Following.
I'm thinking of fitting one to my N53 too, especially after a Terraclean. Quote:
And did you have to do any coding to tell the ECU that the EGR is partially blanked off? Cheers |
05-09-2016, 10:27 AM | #10 | |
622
Rep 3,198
http://www.ebay.co.uk/itm/Vauxhall-V...IAAOxyeZNTUNqP You'll need to check for the size between locating holes. No coding necessary - that's why you use one with the central hole, as it fools the ECU into thinking the EGR's working as normal.
05-09-2016, 04:38 PM | #11 | ||
Rep 113
05-10-2016, 02:57 AM | #12 |
622
Rep 3,198
As I recall access was a bit tricky to one of the bolts on the EGR pipe that you need to split to insert the blanking plate. I think you have to access it through a gap in the inlet manifold.
05-10-2016, 07:00 AM | #13 | |
37
Rep 278
So you blanked the egr pipe at the inlet side? Could it be blanked off at the exhaust side? |
05-10-2016, 09:09 AM | #14 | |
622
Rep 3,198
