2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Ohlins R&T for your F2x 2 series
      02-09-2016, 05:21 PM   #1
HP Autosport
Supreme Allied Commander
3843
Drives: F80 M3
Ohlins R&T for your F2x F3x RWD & X-Drive BMS MU00S1
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within
advanced suspension technology is now available for street cars all over the world.
The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over!
We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide.
> DFV (Dual Flow Valve)
> Rebuildable
> Corrosion salt spray tested (ISO 9227) > 2 year Limited Warranty
This is the latest step in the Öhlins Racing automotive philosophy – Road & Track by Öhlins.
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within advanced suspension technology is now available for street cars all over the world. The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises is over.
BMS MU00/BMS MU00S1
GENERAL FEATURES
> Rebuildable
> 2 year limited warranty
FRONT FEATURES
> McPherson strut
> Single bleed adjuster
> Spring preload adjuster
> Height adjustable (approx. 20-30 mm lower than standard)
> Coil springs (rate 80N/mm)
> Use with original top mounts
REAR FEATURES
> Conventional shock absorber
> Separate spring preload adjuster
> Coil springs (rate 140 N/mm)
CANCELLATION KIT
For cars equipped OE with electronic adjustable suspension, also Öhlins cancellation kit should be used. This kit ordered separately.
Part# 35020-03
Spring Rate
80 N/mm
140 N/mm
***Vehicle with EDC will need to have EDC coded out or emulators installed***
Mounting Instructions:
https://world.ohlins.com/app/uploads...MI_BMSMU00.pdf
x233284.00
      02-09-2016, 05:36 PM   #2
LimeRockM235
LimeRockM235's Avatar
57
Drives: M235i Xdrive
so beauiful
M235,B39,LCSW,ZCW,ZDA,ZDB,ZPP,ZTP,ZDM,ZA5,Z2Q,ZA5, Z2T,Z24,Z3T,Z6Z,Z4F,Z3Q,Z21,Z2R,Z06. JB4,VRFS cattless DP
      02-10-2016, 07:03 AM   #3
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
604
Drives: 2015 F31 xDrive
What's the coin gonna look like on these. Please PM me.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
      02-10-2016, 01:17 PM   #4
HP Autosport
3843
Drives: F80 M3
PM sent.
Price also listed here:
http://www.2addicts.com/forums/showthread.php?t=1224443
      05-23-2018, 06:01 PM   #5
JSCD
Drives: BMW M240i
> Rebuildable
Front
> McPherson Strut
> Spring preload adjuster (approx. 20 mm lower than standard) > Coil Springs (rate 60N/mm)
> Dustcovers
Rear
> Conventional Shock Absorber
> Separate spring preload adjuster (approx. 15 mm
> Coil Springs (rate 160 N/mm)(Additional springs at the rate of your choice will be supplied at no additional cost)
> Dustcovers
> Use with original top mounts F2x
***Vehicle with EDC will need to have EDC coded out***
***Additonal Swift springs for the rear of the vehicle will be supplied at no additional cost to you and at a rate of your choice. Ohlins will use these same dampers for the F2x kit in 2017 with lower spring rates for the rear***
Price for this beautys?
      10-10-2018, 10:45 AM   #6
HP Autosport
3843
Drives: F80 M3
You can now get Vorshlag plates with these coilovers.
      04-10-2019, 07:58 AM   #7
peterswy
Drives: 2017 BMW M240i
Hi HP Autosport & all friends, what is the recommended spring rates when fitting the Ohlins MP00 kits onto a 2017 BMW M240i, with the assumptions of mostly daily commute and very occasional track drive? The car is in stock condition except that the exhaust system was upgraded to Akrapovic kit. Understand that Ohlins kit has published sprint rates of front 60N/mm and rear 160N/mm. Open to suggestions on replacement rear springs as well.
Thanks a lot!
      04-10-2019, 10:48 AM   #8
HP Autosport
3843
Drives: F80 M3
Thanks a lot!
Kindly check our reply to your question in the other thread.
      04-16-2019, 03:48 AM   #9
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
Thanks a lot!
I went with 7kg/12kg swift springs for my M140i, daily driver with occasional track day.
Very happy with it.
dradernh4398.50
      04-16-2019, 11:00 AM   #10
HP Autosport
3843
Drives: F80 M3
Very happy with it.
Those rates will rice nicely on the street and perform well on the track.
      04-16-2019, 12:15 PM   #11
dradernh
dradernh's Avatar
4399
Drives: 2017 M240i
Very happy with it.
I'm using my car the same way, and am running similar spring rates:
F: 350 lb./in. - 6.3 kg/mm - 61 N/mm
R: 600 lb./in. - 10.8 kg/mm - 105 N/mm
For me, there's no compromise on the street, and the shocks & struts do a decent job of controlling the springs on the track.
The car's builder, TC Kline Racing, initially recommended 550 lb./in. in the rear. He increased that to 600 when we decided to install the Turner Motorsport Solid Aluminum Subframe Mount Kit.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro;
GTechniq Crystal Serum Ultra Ceramic; Suntek PPF
      04-17-2019, 08:43 PM   #12
Nugget
Nugget's Avatar
650
They do.
The 16kg rear springs supplied by Ohlins were not very enjoyable on the road.
And I do recommend purchasing from HP Autosport. My front struts came pre assembled with the swift springs and Vorshlag camber plates.
      05-01-2019, 01:13 PM   #13
peterswy
Thanks a lot for your answer. Unfortunately I have already booked a set of MP00 in my home country. Should have bought it from you...
Now the rear springs fitted onto the M240i do seem to be too hard. I'd like to seek your advice regarding replacement springs to work with Ohlins shock absorbers.
As you mentioned the recommended replacement to be 120N/mm springs from Swift, I'd like to know the specific model number please? I also found that 4x904R from Swift for E82 135i is still available. I'm wondering if this set is a better fit for M240i to work with Ohlins DFV (3.5vs vs 6kg front, 9kg vs. 16kg rear)?
Thanks!
      05-01-2019, 01:19 PM   #14
peterswy
Very happy with it.
This setting seems to be right. I'm wondering about whether Swift Springs kit for E82 135i can work with Ohlins DFV on F22 M240i is because I saw that 3DDesign in Japan provides its own suspension kit for F22 with similar spring rates as Swift's E82 kit. URL: http://www.3ddesign.jp/pro_sus_page/1101-22211.htm
Would love to see more discussion and advice on this. Thanks!
      05-01-2019, 01:49 PM   #15
HP Autosport
3843
Drives: F80 M3
Thanks!
Spec-R front springs won't work with the Ohlins R&T, the rears will.
The specific Swift linear rate spring in question is Z65-228-120.
Harold
      05-06-2019, 10:32 AM   #16
xingqianli
Drives: F22
Interested. Can you send pm for the price with installation?
      05-06-2019, 03:31 PM   #17
HP Autosport
3843
Drives: F80 M3
PM incoming!
      05-09-2019, 09:11 PM   #18
peterswy
Harold
Sent PM. Thanks.
      06-09-2021, 02:02 PM   #19
HP Autosport
3843
Drives: F80 M3
Updated part number, new spring rates, and new applications, including X-Drive!
      08-06-2021, 12:26 PM   #20
Kinesthesia
Kinesthesia's Avatar
14
Drives: 2014 M235i
Sweet ! How much?
      08-06-2021, 06:47 PM   #21
dradernh
dradernh's Avatar
4399
Drives: 2017 M240i
Originally Posted by Kinesthesia View Post
Sweet ! How much?
This page might give you some idea of the cost: https://www.hpashop.com/Ohlins-RT-F2...BMS-MU00S1.htm.
      08-21-2021, 12:42 PM   #22
HP Autosport
3843
Drives: F80 M3
That is a very close guess of what the price would be. Price will be finalized once the kits land in the USA.
2addicts
