2010 2011 BMW 5 Series Forum F10 Before/After Dyno results 2011 550i |
02-04-2016, 12:22 PM | #2 |
78
Rep 249
Nice to see another tuner in the ring, but I don't see any benefit over some of the current options.
That said, if it has room to grow or some other options the current piggybacks don't, well then that's another story. Any more details? |
02-04-2016, 01:49 PM | #3 | |
467
Rep 2,416
also what parameters are we able to control with this piggy back?
2011 550i RWD 60-130 7.35
02-04-2016, 02:11 PM | #4 | |
98
Rep 144
The TTFS Race Pack System is an ideal package for anyone looking to upgfrade to the next level. With an amazingly fast 64-bit processor, our Race Pack system communicates with your BMW's DME faster than any other piggyback on the market today. It has an option to configure up to 9 different map settings which are custom configured before shipped out. Generally two maps are set up, one for 91 octane and one for 93 octane. The TTFS Race Pack does not manipulate fuel pressure or knock control hence leaving all the factory safety feature in place for engine protection. It will not throw a check engine light and it may be installed in under and hour. The open loop system allow the Race Pack to be removed in seconds with-out any splicing or cutting. Our extensive testing shows that the Race Pack system outperform the competition of similar set up both on the track and on the dyno! Performance Specs: HP Gains: 45+ WHP over stock configuration Torque: 81+ ft-lbs of torque Key Features: -BMW factory-style harness with dedicated hardware for discrete mounting -When removed, it leaves no trace of installation (no cutting) -Included bracket for discrete install -Waterproof housing -No cutting or wire splicing -Easy installation I can check but I do not think we need any independent testing. We have had this out for some time with a lot of testing and units sold. |
02-04-2016, 02:20 PM | #5 |
ZEROdoubleZERO
228
Rep 659
The baseline of 339hp seems a little low to me, I've seen other stock cars put down more than that. There must be something wrong with the test car or your pulling some trickery to make your tune look good. It's been proven these cars make over 425 crank horsepower and were supposed to believe your car lost almost 90hp thru the drivetrain??? I don't think so, please explain this......
02-04-2016, 02:30 PM | #6 | |
467
Rep 2,416
02-04-2016, 02:41 PM | #7 | |
98
Rep 144
02-04-2016, 02:43 PM | #8 |
98
Rep 144
02-04-2016, 03:05 PM | #9 |
Joint Chiefs of Staff
24317
Rep 191,040
What sensors does this tune connect to?
02-04-2016, 03:07 PM | #10 |
467
Rep 2,416
so as i said i can be the 550 car, we are not M cars.
02-04-2016, 03:14 PM | #11 |
78
Rep 249
What signals does your piggyback tap into? I assume TMAP sensors, but you state no fuel signal and "no cutting or wire splicing". Is there a pin-in, pin-out swap of wires required?
Also, what is up with the graph at the beginning (both stock and piggyback) and the end (stock)? Were those due to shifts of the transmission? What gear did you perform those runs in? It looks like a 3rd gear start, shift to 4th and perform the run, with an accidental shift to 5th on the stock run.
2011 BMW 550 i / Sophisto Grey / BMS Stage 2
02-04-2016, 04:03 PM | #12 |
ZEROdoubleZERO
228
Rep 659
02-04-2016, 04:30 PM | #13 |
348
Rep 1,407
Any pictures of the actual piggyback? Independent testing would be nice. Right now you are pumping out less power, about 20+ whp/25+wtq than a BMS Stage 1.
I agree that the baseline numbers are horrific.. if you factor in what other cars are dynoing at your basically at a BMS Stage 1. Now the million dollar question is: Are you able to log and change settings like the BMS? |
02-04-2016, 10:29 PM | #15 |
24317
Rep 191,040
Thank you
It sounds similar to the A8 am i right?
02-04-2016, 10:44 PM | #16 | ||
98
Rep 144
Both were 4th gear runs with shift up top. PM us if interested, we will give you a good deal. Quote:
02-05-2016, 07:28 AM | #18 |
78
Rep 249
Look, there are more powerful options on the market, but I really do appreciate you providing dyno graphs. There are other companies (look at my profile picture for a guess who) that provide no concrete proof that anything they make actually improves performance.
That said, I've done some math based on stock dyno graphs from a DynoJet, I have whp -53.2 and wtrq -54.6 when compared to a DynoJet dyno run. Sure there are variables, but that's what I can see. So the DynoCom is reading roughly 53 low for each. Add those numbers to what you got after the piggyback install and I come up with 452.7 whp (399.5 + 53.2) and 489.9 wtrq (435.3 + 54.6). That's not bad at all. If you have some room to grow, with a possible stage 2 later to include some other options you might be onto something. Before you get flamed too much for numbers that are lower than the piggyback of choice for most of us, I wanted to say thanks for offering another option for a platform that has no future ECU tuning ability. While most tuners have done all they plan to do for the 2011-13 N63s, you are continuing to tinker, which is all good in my book.
02-05-2016, 09:23 AM | #19 | |
98
Rep 144
Follow us on Instagram or Facebook, we update regularly. We have a lot in store for 2016 |
02-05-2016, 10:21 AM | #20 |
348
Rep 1,407
Thinking about it this is pretty impressive. You should give your tune to badblack550xi so he can test and review it. He's very well respected here on the 5 boards!
02-05-2016, 02:10 PM | #21 |
467
Rep 2,416
What he said.
02-05-2016, 02:33 PM | #22 |
98
Rep 144
