Longest mileage on original water pump?
02-02-2016, 05:15 PM | #1 |
34
Rep 557
Waterpump finally went on the car after 285,000km never changed since I bought the car. Not that I should have/was lazy, it just never leaked and ran solid. Have a feeling it could've lasted longer and got hit when the radiator was changed last month due to a crack.
02-02-2016, 05:19 PM | #2 |
23
Rep 85
I replaced mine with turbos before 100. No issues but while I was in there I figure i'd be able to go another 100 without worry. Based off what you've said, maybe another 30k-50k and I will replace radiator.
02-02-2016, 06:27 PM | #5 |
426
Rep 2,136
140k miles on the clock and still rocking the original water pump and fuel pump
Car is FBO running 17psi on pump gas and 19 on E70 mix Last edited by Gizm0; 02-05-2016 at 07:05 PM.. |
02-02-2016, 06:41 PM | #6 |
Diamond Geezer
212
Rep 2,385
Drives: Jet Black 2007 328i Saloon
I euthanized mine at 145k miles. It was working fine but I needed a new thermostat so I went ahead with wp replacement as well.
02-02-2016, 07:07 PM | #7 |
19
Rep 150
Replaced mine on 110k as preventative, worked fined. Rather didn't change it, since I'm guessing it could run much longer. 35k on replacement, so far so good.
02-02-2016, 08:09 PM | #10 |
39
Rep 592
2009 N54 at 54k miles
2011 N55 at 50.5k miles Both under 5 years in service.
Evolution Racewerks FMIC and Charge Pipe with TIAL-Q.
Wedge Tuned 93 Oct, K&N Panel, Conti DWS 245/275. |
02-03-2016, 06:59 AM | #18 |
13
Rep 43
108,000 on the original water pump, 2010 328i, and I'm going to have a new one put on at 110k along with a transmission fluid change on the automatic (even if BMW says it's a lifetime fill)
02-03-2016, 07:54 AM | #19 |
41
Rep 428
71k and it was an instant gonner
M-Sport|OFT Tune|PE Exhaust|VRSF CP|Coded/Alpina Flash|15% Tint|Cyba 3.8 Chrome Tips|Splitters|Lux H8 160|M3 Spoiler Lip|Gloss Black Grille|12mm Spacers F/R
02-03-2016, 09:19 AM | #22 |
3973
Rep 7,215
currently at 113k. I changed the error codes so they should trigger an MIL (for pump underspeed/overcurrent etc). We'll see if that gives any better warning. On one hand I want to replace it ahead of time, on the other I want to see how far it will go.
I've seen N52 pump/tstat kits on ebay for under $300. Anyone try one of those? Seems tempting but I can't imagine it's OEM quality. Not unless the cost of manufacturing pumps has dropped dramatically. |
