Vibration in steering wheel when braking hard at higher speed
01-30-2016, 05:13 PM | #1 |
35
Rep 196
Thought I'd ask some of the more seasoned experts - any thoughts on ruling out what would be causing this? The steering wheel shakes only when braking fairly hard AND generally at a moderate or higher speed of travel.
The brakes work great, and most of the time don't vibrate. Tons of life still left in them, so I'm not really keen to shotgun all the parts just to see if that fixes it. I put the car up and the front wheels spin freely without any spots that seem to drag (such as from a defective rotor). My thought is that maybe the brakes are fine and I've got a weak part in the suspension such as a tension strut. Car has close to 88k. Any thoughts or even better, any way to diagnose what is at fault here? Thanks for the advice! |
01-31-2016, 01:22 PM | #4 |
35
Rep 196
Excellent - thanks for the responses! Does that means it is suggested to upgrade both the upper and lower arms, or is it just one of them that is generally needed? Is there any alignment needed after this work?
Anything else that should be swapped while apart? I was looking around and saw that Turner has a kit, for instance, that also includes the headlight adjusting rod and front upper inner bushings. |
01-31-2016, 05:06 PM | #5 |
Where'd my VTEC go?
481
Rep 6,067
The upper control arm (tension strut) from the M3 is pretty much physically identical to the non-M RWD one, just stiffer bushings on it. It's an improvement over stock, but probably not too noticeable.
The lower control arm is the one that makes a huge difference because it adds -0.7 camber to the front. This gives you much sharper turn in and lateral grip in the front. If you do the M3 lower front control arm, you will need a new headlight adjustment rod because it connects differently. Alignment is absolutely required afterwards.
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
01-31-2016, 06:47 PM | #6 | |
1233
Rep 3,778
Drives: '11 328i '19 M6
2011 E90 328i 6MT, BMW Aero, CF hood/boot, PI+CAI+RM+3IM+BPC, SS+CI528+ThermoTec+SS#1+2XBurns, AKG 75D eng/trans, Al/Delrin diff/RS, CM 850, UCP, CAE, AKG DSSR, DiffsOnline 3.91 30/90 LSD+BW cooler, C&R, Setrab, Accusump, AST 3-way+Swift, Aurora PR+BW spherical, Vorshlag CPs, M3 brace+UR bar, ARC-8 18x8.5, 255 R1R, RB/CSL rotors+cooling, 135i calipers, RS29, RT700, Safecraft, OMP HTE-R+804F+QD Superquadro, 6pt cage+FIA, Braille, RT DL1Mk3
01-31-2016, 07:07 PM | #7 |
4276
Rep 9,209
... and none of it (control arms) will remedy the brake issue, it will only disguise it. On older generation BMW's yes, due to suspension design, on newer no. Since you don't experience vibrations all the time I would say is brake pad deposit. Solution would be more aggressive pads and change of your braking habits.
One could read hundreds of threads about people replacing the control arms and still experiencing brake pulsation. Why? Also, why most of the time OP doesn't have brake vibrations. If bushing is gone, worn out, is permanently gone. It will not sporadically get better and not cause brake vibrations. In fact just the opposite would happen. Vibrations would be regular occurrence and more violent in time. That is why I say is brake pad deposit and OP braking habits. Last edited by feuer; 01-31-2016 at 07:14 PM.. |
01-31-2016, 07:20 PM | #8 |
4276
Rep 9,209
01-31-2016, 11:18 PM | #9 |
88
Rep 358
I'm with feuer on the brake pad deposit side of this. Before you start tearing into your suspension, find an empty country road and do 6 or 7 max braking events from 80 to 40 and see if that helps. Free and fun.
Had to do this every now and then when I was running yellowstuff pads on old OEM rotors over the summer. |
02-01-2016, 02:59 PM | #11 |
35
Rep 196
Wow, quite a discussion! For the record, the car has done this since I got it. In hindsight, I should have pressed harder about the issue.
Re: pad deposits, I've tried the country road braking procedure already and the problem still remains. If it made any difference in the feel of the brakes, it wasn't significant. That's why I checked to see if the wheels turned freely - but I didn't encounter the drag I would have seen on other cars in the past (which had cheaper or inadequately sized rotors that had warped). So, if the max braking exercise didn't yield anything would you still suspect brakes over suspension? The big problem with seeing suspension wear increase in severity over time is that I don't drive a ton. I've had the car almost 3 years, but it has only had about 7k of mileage in that time so if something is degrading, it isn't as obvious as with someone that racks up that amount of mileage in less than a year. |
02-26-2016, 11:15 AM | #13 |
476
Rep 1,191
Drives: 2009 BMW 328i Wagon
02-26-2016, 11:40 AM | #14 |
4276
Rep 9,209
You are missing my point. Is not that is immune to busing wear but is less prone to brake vibration due to suspension component failure, and that is due to suspension design which is completely different than previous generations.
02-26-2016, 12:29 PM | #16 | |
35
Rep 196
Everything is OEM - services were performed at the dealership by the previous owner. |
02-26-2016, 01:00 PM | #17 |
4276
Rep 9,209
From suspension components the struts and shocks are extremely short lived compared to other cars. The rest of the suspension is OK
02-26-2016, 02:10 PM | #20 |
20
Rep 241
02-26-2016, 02:25 PM | #21 |
4276
Rep 9,209
