57 E92 325d auto slows down too much?
01-21-2016, 01:23 PM | #1 |
Rep 5
Forgive the weird title, not too sure how to concisely describe this problem!
Anyway the issue is that the car seems to 'drag' as soon as I let go of the accelerator. It feels as if it's stuck in a low gear and the engine breaking is pulling it back - but the gears seem to be OK. Is this normal behaviour? It slows down so much I've noticed I'm braking significantly shorter distances than most cars! (I think the average driver brakes too much anyway but besides the point ) I've driven plenty of other cars including: e90 320d, e46 325i and a 730d none of which exhibited this behaviour, at least not as much. All were autos. Any ideas? |
01-21-2016, 01:40 PM | #3 |
146
Rep 2,337
Doesn't sound right. Mine rolls pretty far on lift off.
Have you tried neutral? Other than that it could suggest maybe the brakes are on slightly. Check the temps of your brakes after a drive around (try not to brake!). Be careful, they may be hot! |
01-21-2016, 05:40 PM | #5 | ||
6659
Rep 15,858
Do you mean a gentle lift off of the throttle, or when you lift off fast. The first case, the car should coast without too much resistance from the drivetrain. The latter, that can be the gear change suppression function. From BMW... Quote:
01-22-2016, 08:25 AM | #6 |
175
Rep 1,596
Older Autos would disengage the lockup clutch when you lifted off the throttle, leaving you with no engine braking, the engine RPM's would also drop down to idle.
Newer cars can keep the converter locked, giving you engine braking, as it saves fuel. A sign of this is that the engine RPM's WONT fall back to idle when you lift, it'll stay up. |
01-22-2016, 03:03 PM | #7 | |
6659
Rep 15,858
Back to the OP's situation, I'm surprised if it holds back to feel intrusive on normal deceleration. My E91 330d would stay in the same gear until about 1,100 - 1,200rpm and then change down, much as you would in a manual on easy slow downs. Current 535i with the 8-speed is even more gentle, goes down to about 1,000rpm on the gentle over-run, before a down change. One thing I have noticed, if I'm in traffic and follow other cars slowing down without braking, (clearly they are on the over-run). I often have to use my brakes, as my car runs on much easier and I catch them up. Partly the weight of the 5-series, but it does seem to run on more than a lot of other cars. I have to nudge it down a couple of gears if I want any engine braking. Then we know diesels and petrol engines without throttle plates (valvetronic) have little engine braking anyway, unless we use higher revs to get some additional 'friction' to assist us. |
01-24-2016, 04:41 PM | #8 |
Rep 5
Thanks for all the replies guys, I will check the revs next time and also make a mental note of when it's changing gears.
Still definitely slowing down much quicker than any other car I've driven! Makes me think I'm getting less mpg as I'm giving it more gas once traffic moves off again (when driving I plan quite well so there's not a lot of braking) |
