TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Europe (Continental) > Half check engine+Valvetronic motor issue+Lack of power
      01-09-2016, 08:12 AM   #1
sandbravo
Drives: 320i e90 2005
Exclamation Half check engine+Valvetronic motor issue+Lack of power
Hello, Im new here from Norway. Have a 320ia e90 2005. The problem comes with every cold start, pops up half check engine light (Power Reduced), Fault codes: 2A69 Valvetronic Voltage Supply Servomotor 1, 2A6B Valvetronic Power Limitation Servomotor. The car runs on Limp Mode. When the engine is hot, I erase the fault with Carly or torque, the car leaves the Limp Mode but I feel a distinct lack of power.
I've taken the engine noise protection to see if I can do it by my self but do not dare. I do not see how to takes it out. As extra information, I have seen the connection of eccentric shaft sensor is soaked in oil, but does not leave any fault code related to this sensor.
Should I go ahead and replace the VVT motor or it could be something else?
I'm really desperate, if any expert on BMw's or someone who has been the same, please contact me.
Regards.
      02-14-2016, 08:53 PM   #2
edy74
edy74's Avatar
Romania
133
Drives: CUSTO///M E90 , 640d xdrive
2006 318i  [9.00]
Hi!
I have the same problem with my 2006 318i, 2A69 code, half engine check light, no power.
Did you fix your car? What was the problem?
      04-27-2016, 11:17 AM   #3
sandbravo
Originally Posted by edy74 View Post
Hi!
Unfortunately not, the failure still appears sometimes. Did you fix it?
