02-25-2008, 01:46 AM | #1 |
Rep 135
track wheels
Does anyone have some suggestions on some good 17" light wheel for the Z4M setup? Would 17" even work on the car? (clear the brakes)
thinking about something like the Kosei K1: http://www.tirerack.com/images/wheel..._sil_ci3_l.jpg thanks |
02-25-2008, 11:03 AM | #2 |
My favorite sign.
169
Rep 4,333
17's should clear the brakes if you have stock brakes on the car. A lot of people run 17s for winter.
As far as suggestions, I'd suggest that you look into buying a wheel made of 1 or 2 pieces with forged construction. Spun cast is probably the best casting method. You want the wheels to be both light and strong.
02-25-2008, 12:09 PM | #3 | |
64
Rep 666
Drives: 2023 Hyundai IONIQ 6 SEL AWD
Why 17 inch wheels?
If you plan on racing your Z4MC then you want the lightest, strongest wheels you can afford. If you're planning on driving school/autocross use then wheel weight will not be your limiting factor. I found a set of beat up E46 M3 18 inch wheels Style 67 that have offsets close to the stock wheels and are a good fit. Mount some Toyo R-888 tires and you're ready the go.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red SOLD: 2007 BMW Z4 M Coupe Imola Red |
02-26-2008, 01:11 AM | #6 |
64
Rep 666
The E46 M3 Style 67 wheels are: 8X18ET47 and 9X18ET26
Jim Millet
02-26-2008, 01:23 PM | #8 |
Rep 135
I'm looking at getting some rims that are 18x8.5 ET42 and running at 10mm spacer in the rear. Does this sound like it would fit the z4ms?
This would make it Front: 18x8.5 et42 Rear 18x8.5 et32 Thanks for any input. |
03-03-2008, 12:29 AM | #9 |
Rep 12
I actually had the same dilemma a few weeks ago. I ended up going with the Volk RE30 because they were forged and not cast like the Kosei. I purchased them at Tire Rack and I am not using spacers.
I needed DOT tires so I could drive to the track because there is no room in the M Coupe for an extra set of wheels. I went with Nitto NT01 235/40 R18 up front and 275/35 R18 in the rear. I love the set up. |
