F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Suspension | Chassis | Brakes > 335i rear brake upgrade options?
Extreme Powerhouse
      01-06-2016, 10:05 PM   #1
kromix
kromix's Avatar
263
Drives: '16 340i AW MSport
2016 340i (F30)  [0.00]
What options are there to upgrade the rear 335i floating brake? The one with the smaller rotor?
      01-06-2016, 11:05 PM   #2
Project Elite
Project Elite's Avatar
137
Drives: F30
I assume you have the factory 340i rear brakes from the base/sport line, which is the single-piston caliper paired with a 330 mm rotor.
For your car's REAR brake, you have two very similar options:
-upgrade to M-Sport 2-piston Brembo brakes with 345 mm rotors
-upgrade to M Performance 2-piston Brembo brakes with 345 mm rotors
Only difference between the two is aesthetics and pads. M Sport pads are more aggressive than M Performance pads and give a bit more initial bite. M Performance and M-sport rear brake pads are also interchangeable FYI.
Hope this helps.
      01-28-2016, 08:32 AM   #3
racingbrake
32
Drives: M3
RacingBrake has two piece rotors made for track duty and fit OE caliper:
http://www.racingbrake.com/Two-piece...EAR-p/2159.htm
Comprehensive review on 335i with track feedback.
RacingBrake 2 Piece Rotor Review!
In stock.
Thank you.
f30post
