Any way to get TOSLINK input to logic 7
01-04-2016, 02:55 PM | #1 |
30
Rep 124
I've been pulling my hair out over this. I really really really want to use TOSLINK or coaxial digital input to pipe audio to the stock radio (professional, non-idrive, logic 7). As far as I can tell, everything is now MOST, so my only hope is to find something like a CD changer emulator that will pipe TOSLINK/coax digital input over the most bus. Unfortunately, I can't find a product that does this. Does anyone have any ideas or has done something like this?
01-04-2016, 03:37 PM | #2 | |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
01-04-2016, 03:47 PM | #3 |
30
Rep 124
Hmm, that's a huge shame. It's part of my plan to have a Chromecast audio handling audio streaming. It's far better audio quality than Bluetooth AD2P even with aptx. I have a preliminary set up working now, but I've been highly disappointed with the aux in quality. The Chromecast audio supports TOSLINK out and I'd love to find a way to pipe digital audio into the stock radio somehow.
01-04-2016, 05:08 PM | #4 |
300
Rep 3,969
Why would you want to do that? That's like feeding your dog filet mignon and expecting its poop to stink less.
01-04-2016, 05:13 PM | #5 |
300
Rep 3,969
Not quite, the Mobridge converts the MOST signal output into an input for aftermarket amps. OP wants to be able to input into the MOST loop and playback on OEM system.
01-04-2016, 05:18 PM | #6 |
1911
Rep 13,103
Shoot first aim later
I guess I have been watching Donald Trump to much. You could get a Dension 500s bt at least its usb direct to most bus. Or for than matter if you have BMW usb its still digital direct as much as possible. Last edited by ctuna; 01-04-2016 at 05:30 PM.. |
01-04-2016, 06:37 PM | #7 |
30
Rep 124
Thanks for the help guys. Sounds like I may be out of luck. I'll try a ground loop isolator on the aux in and see if that improves things.
As for the why, the stock system doesn't sound bad to my ears when playing CDs; I just want that audio quality fromy other sources (also the Chromecast audio is crazy convenient, makes it duper easy for passengers to switch off playing music). |
01-04-2016, 07:12 PM | #8 |
1911
Rep 13,103
Aux input is noted to be low fi
Some say feeding it with a high quality head phone dac helps. and/or described in the following thread. http://www.e90post.com/forums/showthread.php?t=1002984 See entry 80 and most of agentfishes comments. |
01-04-2016, 07:21 PM | #9 |
30
Rep 124
I'll check it out; thank you! It looks like this guy has exactly the same goal as me, but with airplay/idevices instead if Chromecast/Android.
01-04-2016, 07:33 PM | #10 |
30
Rep 124
Ok, looks like I could use something like this: http://www.amazon.com/gp/aw/d/B00934...SXBV6PSR4PVVDJ
Still seems a shame we can't get digital input. I have 6fl, any hope in that avenue (some way to convert TOSLINK to USB)? |
01-04-2016, 08:50 PM | #11 |
69
Rep 994
All you can do really is recode to hifi and do something like match pp82 and then you can have a better amp and have your toslink
iPhone 6 Plus (iTunes library/iTunes radio/Waze, etc) to Airport Express via AirPlay. Toslink out of Airport Express to Helix P-Six DSP. PHD AF 1.C tweeters, PHD FB 4.1 midranges. Jehnert Door Cards and mid-bass'.
01-07-2016, 07:09 PM | #12 |
30
Rep 124
Alright, so I bought that DAC I linked above as well as a ground loop isolator. Also bought a 12v to USB adapter in case the car's is noisy.
The end result massively exceededy expectations! Holy crap this sounds so much better; given high quality source I can't distinguish between this and a CD. |
01-07-2016, 10:05 PM | #14 |
Rep 117
I don't feel that my cheap little Bluetooth receiver plugged into aux in has SQ anywhere near Bluetooth streaming right to my stereo in my accord... Are you saying you stream music to Chromecast, optical out to that DAC, then the line out from the DAC to the aux in and that makes it sound better?
01-07-2016, 10:16 PM | #15 |
1911
Rep 13,103
Bluetooth streaming is not as good as Wi Fi
Bluetooth streaming is not as good as Wi Fi or USB
the bandwidth is more limited. The big limitation is your stereo equipment and the source data . And in the case of a BMW the aux is crappy. Also any direct analog output form a phone is suspect. |
01-08-2016, 07:46 AM | #16 | |
30
Rep 124
Yep, exactly. The exact chain is: Chromecast Audio (TOSLINK) -> Fiio D3 DAC (Line Out) -> PAC SNI-1 Ground Loop Isolator -> AUX In. In order to use the Chromecast you need an active WiFi network in the car. I am using an ATT OBD2 powered hotspot that turns on with the car. I will update this post with pictures of everything later. A few thoughts: The Chromecast directly to aux in sounds pretty bad, not sure why. The ground loop isolator helped a bit, but I still wasn't happy. The ground loop isolator may not be needed with the Fiio D3, the sound with and without is very close. I think I noticed a subtle improvement with it, so I kept it in the chain. Powering things from a USB charger instead of the car USB port made a small difference, perhaps due to cleaner power or perhaps due to a ground loop reduction. Here are some pictures of the setup. I have tried to keep things semi neat (I may get a shorter optical cable in the future, but I had this one on hand and it was high quality so I shouldn't have issues with it coming loose). Although it's not exactly an invisible install, it does leave the console pretty much free and still provides access to the cup holder. I used a right angle flat OBDII extension cable and filed a tiny notch in the back of the door to run the cable through. This way I can leave the door cover on and mount the hotspot with a little bit of Velcro. Last edited by Varjo; 01-08-2016 at 09:39 AM.. |
ppointer743.00 |
01-08-2016, 05:09 PM | #17 |
Rep 117
that seems a little unnecessary to need a hotspot to connect the phone and chromecast audio... wonder why they didnt make it so that you could set up an adhoc network or whatever its called and connect directly to the phone.
01-08-2016, 06:28 PM | #18 |
1911
Rep 13,103
BMW is really behind on car electronics
for entertainment and communication. It wasn't till 2011 that they had bluetooth streaming in there cars. Plus when car manufacturers integrate this stuff into the car they don't consider how easy they can make it for aftermarket addon's. It was much easier when the stereo was a standalone piece of equipment. |
01-08-2016, 10:30 PM | #19 |
30
Rep 124
It's somewhat annoying, yes. The issue is that the Chromecast needs both internet access (it streams directly from it's Audio source most of the time) and to be on the same WiFi network as a phone. You may be able to get it working by enabling tethering and using Chromecast guest mode, but it was no big deal for me to add the hotspot to my att account.
01-08-2016, 10:51 PM | #20 |
1911
Rep 13,103
ATT data plan is not cheap
are you streaming from an Internet Service or simply playiing files from your phone? |
01-08-2016, 11:17 PM | #21 |
30
Rep 124
You can stream files from your phone to the Chromecast without using any data. I also use some internet radio apps which cause the Chromecast to pull the info directly from the cloud. It's the same as with Bluetooth, you can use local media or data intensive apps. I use a mix.
01-21-2016, 12:52 AM | #22 |
T667YM86
67
Rep 244
Mulf2 and mulf2h have aux in which works through ADC. There is I2s bus between ADC and MOST-bus transmitter. So you can use any source with i2s output. I'm planning to mate airplay device (air enabler) and "usb to i2s" transport (based on pcm 2706). I'll report if it will works or not.
