BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > AUDIO/VIDEO + BLUETOOTH + Electronics/Alarm/Software > Steering Wheel "Phone Button" Wiring
      12-30-2015, 12:57 PM   #1
thethief1
Drives: E90 316i Sedan 2011
Exclamation Steering Wheel "Phone Button" Wiring
Hello to all,
First with all my respect to brilliant DIY guys here.
I have a 2011 E90 316i Sedan with BMW Professional Audio. No iDrive, No Bluetooth, No Sport Wheel, No Cruise Control, No Seat Heaters.
I have a 3rd party Bluetooth Car Kit (Belkin CarAudio Aux) which I love it. It is a simple "Lighter Powered Bluetooth Aux-in" car-kit. It has it's onboard MICROPHONE and a button for some functions like hang-up, play,pause etc.
What I want to do is; to connect the PHONE button (which is located at the bottom- right on the left side of the steering wheel) to Belkin's Button.
I soldered all necessary wires and extended bluetooth's main module which allows me to control with an external switch. All functions work like a charm. Also I installed the module into the front-dome to place the MIC into the right place. There's no problem up to here.
I took the airbag and Steering Wheel trim off and got into the circuit-board.
It was too hard for me to figure out this digital signal flow so I found another way.
Now I have two wires attached to my PHONE button on my SteeringWheel. And when I connect
the main module's switch to these wires, I can fully control the module. Everything works fine. Also all other multifunction buttons on the steering wheel are working to.
So, wires that I prepare are on the Steering Wheel side.
The point where I get stuck is getting these two wires after the COIL SPRING connections.
I have 6-PIN socket in the Steering Wheel, 4th and 6th pins are empty. (Photo Credit: 1AddictsAnonymous)
And There are two sockets one with 6PIN and one with 12PIN, after the COIL SPRING.
Which pins should I have to connect to get the signal? Without affecting any other system functions also.
Thanks in advance.
      12-30-2015, 05:14 PM   #2
kentgbr
Member
kentgbr's Avatar
28
Drives: 2016 340i Sedan
Originally Posted by thethief1 View Post
Hello to all,
Thanks in advance.
The left-side wheel module control signals are brought out on pin 2. The right side module control signals are on pin 1, pin 3 is common to both. Pins 4 and 6 are for paddle-shift up/down signals, which is why they are empty on your car. Pressing the left-side buttons shorts out various resistors between pins 2 and 3, which generates signals that are decoded for each button function. Connecting to and shorting out these wires with the foil switch will disturb these functions. I suggest sourcing some compatible pins for your wires, using the empty pin 4 and 6 locations, and finding the mating connector on the other side. If this is the "after coil spring 6-pin connector" in your picture, check if pins 4 and 6 are empty, and install your BT module control wires in these locations.
Present - 2016 340i, Alpine White, Black, M-sport, 6-spd, Track Handling, Tech pkgs
Past - 2011 E90 335i, Alpine White, Ivory, Sport, Premium, Steptronic
Past - 2008 E90 335i, Titanium Silver, Dakota Grey, ZSP, Steptronic, 6FL, Wagner FMIC, Bilstein B12 Pro-kit, M3 control arms, SS F/R brake lines
      12-31-2015, 12:51 AM   #3
thethief1
Post
Thank you for The reply and suggestions. Do you know which harness socket do I have to use on The after Coil Spring side for these 4th and 6th pins?
Tested
On The wheel Side
pin connector's 1st, 2nd and 3rd pins
With ->
On The After Coil Spring Side
1. I tried The 6pin connector but no matching wires between them. I tested with multimeter, no beep except GND.
2. I tried The 12pin one and then I can Get beeps some of them but they are not in order, (pin1 is not Matching pin1)
I am going to test all wires in detail to figure out which of them matches each other.
Is there any other harness / socket on The after Coil Spring Side, except The ones I mentioned above that I should look for?
      12-31-2015, 12:30 PM   #4
kentgbr
Member
kentgbr's Avatar
28
Tested
On The wheel Side
With ->
You could try bmw-planet.com
Wiring diagrams and connector information can be found at this site:
http://www.bmw-planet.com/diagrams/r.../e90/index.htm
      01-02-2016, 03:33 PM   #5
thethief1
Thank you very much I will check and inform The results.
      07-23-2016, 05:50 PM   #6
zhp pilot
20
Drives: 2017 X5M
Did you ever figure out what wires are what? I'm trying to install a joycon adapter so I can use the steering wheel controls on my tablet but I'm not sure which ones to use. One would assume that the 6 pin adapter on the steering side would matched to the 6 pin coming out of clock spring.
2017 f85 X5M | Donington Grey | Aragon Brown
2009 e90 335i | Black Sapphire Metallic | Saddle Brown
2004 e46 330ci ZHP | Silver Gray | Black (RIP)
Tags
control buttons, e90 2011, multifunction, steering, wheel
