Replacing Instrument Cluster
12-28-2015, 05:02 PM | #1 |
167
Rep 2,445
Drives: 330d M sport
Garage List 2006 335d [0.00]
2006 330D M Sport [0.00] 2012 320d sport [0.00] 2006 Bmw 330d M Spo ... [6.66] 2007 320d M sport l ... [10.00] 2006/56 320d m spor ... [0.00] 2005/55 M Sport 330 ... [0.00] 2007 320d m sport ( ... [0.00] 2005 320 Cd m sport ... [0.00] |
has anyone any ideas how easy this is to do and are the centre displays removable,how do we keep the current mileage
330d M Sport Tourer / Arctic White / 403M Alloys / Privacy Glass / Logic 7 / Heated Leather Seats / High Beam Assist / Bluetooth / Nbt Nav / Auto Lights & Wipers / Front & Rear Park Control /
12-29-2015, 07:27 AM | #2 |
529
Rep 2,503
Do you mean replacing it with a new or used cluster?
If new, it just needs coding to the car with winkfp / ncsexpert or ISTA-P. If used...Use the search my friend Many discussions on this. It's pretty easy, but requires an EEPROM programmer and some soldering skills / test clip to change VIN and reset mileage. Once mileage is reset and vin matches your car, the new cluster will take the mileage from your cars CAS module. |
01-01-2016, 05:34 AM | #3 | |
167
Rep 2,445
I'm thinking of having the old one adjusted as I had new LEDs fitted but clocks are out of line
01-02-2016, 11:04 AM | #4 |
529
Rep 2,503
This is very common when modifying the cluster.
The needles should be adjusted before putting the cluster back into the vehicle. It should be connected to a 12v bench supply on pins 9 and 18. The needle motor should then go to the 'home position' you just be really precise when putting the needles back on. It's really easy to do but takes patience to get it perfect. It's a DIY job, no need to replace cluster. If you don't have a 12v supply then I suppose you could connect the board up to the car and adjust needles whilst seated in the vehicle. Not ideal but perfect possible. |
01-02-2016, 11:06 AM | #5 | |
167
Rep 2,445
I'm going to try my Indy first as he has ramps got to go in between the wheels so the car can we drove on the ramps and if he sets the cruise control to a speed hopefully he will be able to needle and the clocks up
01-02-2016, 11:28 AM | #6 |
Rep 172
Not necessary, mine was out and I got the guy who fitted the led's to adjust the needles. He did what was mentioned above. Can't you go back to the fitter?
01-02-2016, 04:08 PM | #7 | ||
529
Rep 2,503
01-02-2016, 04:10 PM | #8 | |
167
Rep 2,445
The speedo is not bad as in needle to speed but when you set cruise the red line and needle don't line up
