changed plugs and coils do I need to get something reset
12-26-2015, 03:06 PM | #1 |
28
Rep 222
I have a 2007 335i auto recently changed my plugs and coils I have read that there is and reset process can someone tell me what it is please?
12-26-2015, 04:03 PM | #4 |
648
Rep 2,015
Yes reset the spark plugs in the service items. None for coils.
335i e92 TPC 19Ts
12-26-2015, 04:54 PM | #6 |
1706
Rep 14,829
12-26-2015, 05:09 PM | #7 |
28
Rep 222
How do u do a cbs reset? What's happening with my car is on cold startup it idles real rough engine light flashes but after about a minute it's perfectly fine.
12-26-2015, 05:20 PM | #8 |
1920
Rep 13,119
cbs reset only resets the count down counter.
If you want to reset the adaptions you either need a coding setup or scanner capable of doing this. I would be best to scan for codes to get an idea of where the error is coming from. There are some other ways to reset the adaptions one of which is disconnecting the battery. If it was working before you changed this stuff there is a good chance that some of it is bad. Did you get the proper plugs and check the gaps before you installed them? I would check they new plugs with the old coils first so you are not looking at two sources of problems at once. Could be just a seating problem with the coils to. |
12-29-2015, 01:20 PM | #10 |
28
Rep 222
Purchased plugs from bmw and one new coil is faulty so plugged old coil in and car is running perfect again so gonna go back to eurocar parts and tell em there plugs are no good and coil and try and get a refund.
