12-22-2015, 03:06 PM | #1 |
80
Rep 694
Pictures of Dash cam set-up
Has anyone got pictures of their dash cam to see location and size.
I had a mini 0805 for a week (Needs to be small and discrete) but some problems with it so will be returning it and looking for something else Price range no more than £80 as it is my first dash cam. |
12-22-2015, 04:27 PM | #2 |
Supreme Being
1804
Rep 5,425
I have photos somewhere but at a higher price range since I have the ThinkWare 2ch.
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
12-22-2015, 04:33 PM | #3 |
10994
Rep 32,881
Definitely the best one around that price is the Transcend Drivepro 200, I have it and an A118C and although the A118C has a great form factor, it doesn't have playback through the display or the wifi to play back or transfer videos to phone/tablet that the DP200 has.
DP200 is still pretty well hidden behind the rear view mirror. |
12-23-2015, 07:03 PM | #5 |
759
Rep 1,863
I have a mini 0806. I'd be interested in the problems you had with the 0805.
BTW I had to locate it on the left side in front of the mirror as it doesn't fit on the right and it would cover a sensor . Last edited by Nobby Clark; 12-24-2015 at 09:02 AM.. |
12-25-2015, 08:35 AM | #6 |
167
Rep 375
This is my Blackview DR650 set up.
Mounted as high as possible on the windscreen above the drivers seat. I have my seat on the floor so it isn't in the way and I prefered this position rather than next to the mirror. Back camera mounted on a home made bracket in the back of my F31 which slots inside the headlining and is held by the rubber. Was too much trouble to mount on the tailgate because of the split tailgate. Only visible cables are the inch or so to each camera. Cable from font to back was run along the floor to try to avoid the DAB issue which it has done. Connected to a Powermagic Pro. Both 12v permanent (straight to battery) and the switched 12v supply (fuse 162 12v sockets) are connected via fused connections. Parking timer set to 6 hours to avoid running the battery down too much. Any questions just ask. Dave.
F31 335d xDrive MSport touring.
Sapphire black with Coral leather. Ordered 27\03\2015, Build Finished 17/4/2015. Collected 20/05/2015. |
12-25-2015, 09:52 AM | #7 | |
80
Rep 694
I charged it overnight and installed in the car the next day, give or take a couple hours. It was plugged under the under the glovebox. My issue was that it worked striaght away after full charge. (Blue and red flashing) which means it was charging while driving, which I found weird as it was charged for 12 hours. After a couple minutes it blue flashing ( fully charged and recording) If the car was left for more than a 4/5 hours or overnight. (1 min switch off after car) the camera would end up dying. This meant that when back in the car it would be solid red ( charging but not recording) So i figured the inside battery must have been the problem |
12-25-2015, 09:56 AM | #8 | |
80
Rep 694
Unfortunately its my first camera so blackvue is out of my budget and I think for now Il probs just stick to front camera. Might try putting the next camera at the same position to see though |
12-25-2015, 10:56 AM | #9 |
167
Rep 375
I had a Mini 801 in my Renault previously and despite being a budget camera is was quite good.
With the Blackvue being Wi-Fi you can see what the camera angle will be like before you stick it to the windscreen. Dave
12-25-2015, 01:23 PM | #10 | |
759
Rep 1,863
I think a blue light means it has power and flashing red is recording. The internal battery should last, according to the manual, 10 mins but it lasts nowhere near that. That said you had it plugged in to power ( the cig lighter) so the internal battery shouldn't matter. I found the solid red light problem occurred if you had the SD card set to auto rather then selecting just one slot. |
12-25-2015, 04:17 PM | #11 |
80
Rep 694
Wifi would be a good option rather than keep taking the card out to review footage I suppose
12-25-2015, 04:20 PM | #12 | |
80
Rep 694
Flashing Blue - Fully charged and recording. Solid blue - using internal battery and charging. Flashing red/blue - connected to external source while recording Solid red - charging no recording Im not sure if the 0805/ 06 differ between the lights then or not. Also the 0805 doesnt have two microsd slots like the 806 does (if the 0806 do) I went for the 0805 as heard they were the most reliable. How long have you had yours and how is it connected ? Any problems? |
12-25-2015, 05:07 PM | #13 |
319
Rep 821
I am going to order a Thinkware F750 2 channel (front & rear) camera for my new 335d Touring. The F750 has everything I need in a camera. I also have a Blackvue 650 which I have just taken out of my RRS. Good camera but suffer from overheating. Already had it repaired due to this, so upgrading to the Thinkware camera next.
12-25-2015, 06:17 PM | #14 | |
759
Rep 1,863
Occasionally, I get the solid red light - not recording. It's annoying because you end up regularly checking the light is flashing. On both set ups I have the cameras conected via a Blackview Power Magic Pro which allows the cams to run from the car battery after the power is shut off with voltage protection so you don't run down the car bar battery. This us optional but the set up is pretty much the same. On the BMW I ran the cable from the cam, along the headlining to the drivers A pillar. I removed the A pillar cover and made sure the cable as clear of the airbag and followed the other cables down the A pillar. Note there are videos on YouTube that suggest you just tuck the cable across the top of the A pillar. Don't. It's where the air curtain is. From there I tucked the cable under the door trim to the back seat. Pass the cable under the back seat and you get to the fuse box. Because half the car shuts down at various times after locking, I took the permanent live feed straight from the battery (add an inline fuse). Earth to chassis or negative battery terminal. For the ACC I took the interior boot light fuse via a piggyback fuse holder. |
12-26-2015, 12:13 PM | #15 |
2310
Rep 5,101
Here's mine it's an Amacam AM-M80, pretty cheap at £40 but does the job and is easy to use, just about fits behind the mirror and the wires are completely hidden around the windscreen, the door rubber and down to the passenger footwell power socket, starts with the car so you just get in and drive away, virtually all of my family and friends have bought one since I got mine!
12-26-2015, 01:12 PM | #16 | |
80
Rep 694
And if it does occur how long till its back to recording again? |
12-26-2015, 02:16 PM | #17 | |
759
Rep 1,863
It may be a symptom of the Power Magic box where by its supposed to stay on for 6 hours after power is cut. I think restarting the engine several times (possibly the stop start) plays havoc with the logic and the whole thing locks up. |
12-26-2015, 04:58 PM | #18 | |
80
Rep 694
12-26-2015, 07:13 PM | #19 | |
759
Rep 1,863
I agree it's flaky software though. |
01-03-2016, 09:35 AM | #20 |
602
Rep 2,246
Here's the ThinkWare in my F31. Front camera only currently. Powered by the socket under the glove box. Only visible wire is the 2" run to the top of the windscreen as shown.
03-15-2016, 03:45 PM | #21 |
Rep 2
Hi, Looking for help sorting out the dreaded DAB wipeout problem caused by my DR650 in an F34, and came across this thread... So a couple of questions, if I may ask davybull...
I've been supplied a coax cable by blackvue which they have wrapped in tin foil tape, which is supposed to cure dab problems. I've routed this on the drivers side of the roof/door seals to the rear mounted camera. With the camera mounted top centre, DAB is completely wiped out, but due to the rake of the rear screen, fitting the cam anywhere else is really a nonstarter as there is too much reflection. So I'm thinking your install is worth a try, so..... Is your ingenious headlining bracket installed directly under the shark fin? And which side of the car have you run the coax cable, which I assume is hidden under the door seals etc? Thanks, Gary |
03-15-2016, 04:29 PM | #22 | |
3105
Rep 7,031
Drives: 335xd Msport +
You need to run the wire under the lower door seals/ carpet via the passenger side to avoid dab issues. The dab aerial is located within the headling. You can also get suppresors from Blackvue and eBay etc. One at either end of the cable helps. Did mine this way - f30. No dab issues
