OEM Alarm Question??
12-19-2015, 10:39 AM | #1 |
Enthusiast
167
Rep 1,622
I recently installed the OEM Alarm in my pre 03/07 build E90. I haven't had it coded to the car but so far the car chirps on lock/unlock, clown nose blinks and the alarm goes off if it senses motion in the interior.
My question is that I have noticed that if I unlock the car and open any other door or the truck without opening the driver door first the clown nose blinks very fast and stays blinking even after the car is started and driving until I plug the key into the slot (I have CA). Is this normal for it not being coded, or is there an error somewhere in the system? Thanks for your help! Rik |
12-19-2015, 11:49 AM | #2 |
35
Rep 212
Drives: 2009 328i xDrive
I would assume it just needs coding as you may be tripping a sensor somehow or something but I may be wrong. The way to find out is to get it coded.
12-19-2015, 05:13 PM | #3 |
Enthusiast
167
Rep 1,622
Thanks! I figured as much, just thought I would see if anyone else has experienced this without coding! I'll find a remote coder!
12-19-2015, 06:05 PM | #4 | |
35
Rep 212
12-19-2015, 06:40 PM | #5 | ||
Enthusiast
167
Rep 1,622
01-03-2016, 12:18 PM | #6 |
Enthusiast
167
Rep 1,622
UPDATE:
I had the OEM alarm coded to my car last night and pretty much all the parameters were aktiv besides the panic which I made aktiv. So now I have the panic feature by holding down the open trunk button. But funny thing, I go to fill up gas today, and as always I open the gas door and lock the car after. As I'm filling up the car alarm starts to go off. Now I know the gas door has nothing to do with the alarm so does anyone know what else this could be? Also while the car is running if I hold down the trunk button for panic is goes off, is that normal for the alarm to go off while the car is running? Last edited by ArcticRik; 01-03-2016 at 12:45 PM.. |
01-07-2016, 09:48 PM | #7 |
Rep 117
I got no info for you about what should happen, but I do know it's possible to get into a situation while the car is running that you might "panic", so I don't see why it wouldn't work while running
01-08-2016, 12:54 PM | #8 |
164
Rep 598
My guess is that the car knew the gas door was opened (or you bumped the actuator of the gas door locking mechanism and caused it to think it opened), or possibly more likely, that the weight of the gas caused the car to tilt enough to set off the tilt sensor.
04-22-2016, 01:59 PM | #9 |
Enthusiast
167
Rep 1,622
So another question, is the hood sensor in any way associated with the trunk? Or does the trunk have its own sensor somewhere? This is the scenario that I am dealing with.
1. Car is locked. 2. I walk up to the trunk and open it (have CA) 3. Shut trunk 4. Unlock driver door with CA 5. Turn on car (CA, key in pocket) 6. Drive 7. Get to location, turn off car 8. Open trunk, get stuff, shut trunk 9. Lock car, chirps, clown nose blinks normal 10. Few minutes later alarm goes off This only happens when the trunk has been opened. To remedy this, I have learned that I have to plug the key into the ignition slot, turn the car on and then turn it off. This issue doesnt happen when I plug the key in to drive. It is only with the trunk that this happens. What do you guys think is going on here? Thanks! |
04-23-2016, 04:32 PM | #10 |
164
Rep 598
Can you reproduce it every time? And the time it takes for the alarm to go off, is it exactly the same amount of time every time it happens?
This sounds really odd, and I wouldn't be surprised if no one has a clue. |
04-24-2016, 12:25 PM | #11 | |
236
Rep 358
I have CA and OEM alarm on my 07 335i. My clown nose doesn't do any weird blinking once I'm driving. And I can open/close the trunk without setting any alarm off even if car is locked. It seems to treat the trunk independently, because the doors will unlock once you pull the handle. Of course you can only open the trunk if the car is unlocked, or locked with the key in your pocket. I think either your hood sensor, angle sensor, or motion sensor is malfunctioning or not set up correctly. |
04-24-2016, 01:24 PM | #12 | |
Enthusiast
167
Rep 1,622
04-24-2016, 01:25 PM | #13 | ||
Enthusiast
167
Rep 1,622
