12-18-2015, 11:38 AM | #2 |
71
Rep 510
According to the info on the sticker of the door jam, it is 38 psi. But if you changed your setup and used completely different wheels and tires, then you may want to check the specs on the tires as well.
12-18-2015, 12:02 PM | #4 |
176
Rep 257
J, haven't seen you in a while. I have 255-295 20s nittos with a max tire pressure of 50psi and I run em at 38lbs cold. Might gain 4psi after they heat up from driving. Have a digital psi gauge and portable air pump in the trunk and check on the reg and when there are big temp changes from the weather. Hope this helps.
12-18-2015, 01:23 PM | #5 |
35
Rep 474
Lol yea ive been busy with my personal project so I haven't done anything on the car.
Thanks for the info. But I found out why, there is a long ass nail in my tire. Got it fix. But question, would the alart go away on it own after driving or I'm suppose to reset it myself? |
12-18-2015, 01:58 PM | #8 |
176
Rep 257
Did you reset tpms. Start car, reset tpms on idrive vehicle status, drive for a bit to reset. Should go to green all four tires. Warning comes on with a 3psi or more pressure change.
12-18-2015, 02:04 PM | #9 |
35
Rep 474
Oh...that's why I asked if I have to reset it in idrive or it will reset itself after keep measuring the pressure. So I guess I have to do it. Thanks guys
12-19-2015, 01:09 AM | #10 |
9163
Rep 14,521
whoa it's Jasonle89 from the dead! where you been hiding lol! anywho, what they said...reset your TPMS...it'll tell you how to do it on the screen.
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
12-19-2015, 02:11 AM | #11 |
35
Rep 474
Lol yup. It's me. Been doing other things in life. Travel out of the country. Just got back.
Have u done anything new to your car? And by the way,I reset it. All good. Thanks guys |
12-19-2015, 03:22 AM | #12 | |
9163
Rep 14,521
http://f10.5post.com/forums/showthread.php?t=1195132 http://f10.5post.com/forums/showthread.php?t=1174728 http://f10.5post.com/forums/showthread.php?t=1201766 http://f10.5post.com/forums/showthread.php?t=1177788 http://f10.5post.com/forums/showthread.php?t=1197278
