M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > F10 M5 DIY Guides
      12-16-2015, 07:27 AM   #1
drbru
99
Drives: f10 m5
Removal of rear centre diffuser
Hi all
Im hoping someone can give me some guidance in removing the standard rear centre diffuser as im hoping to install a challenge centre diffuser in its place
I understand that there are just three plastic rivet things that need to be pulled out and the rest is secured by plastic clips...
Anything else I need to know...?
Cheers
      12-17-2015, 06:29 PM   #2
Speed808Ix
Speed808Ix's Avatar
69
Drives: F10 BMW M5
Originally Posted by drbru View Post
Hi all
Cheers
I did this a while ago and I will tell you (sorry if i miss a step)
There are 3 Torx screws (black) in the back loosen those up all the way and tere are 2 plastic tabs on each side (4 total) take those out.
Then start from either side and pull the diffuser out down and out and it should unclip slowly. when the whole diffuser comes out the middle plastic piece will be tricky and be careful not to break the plastic tabs but they should unclip if you pull the plastic piece and the challenge piece goes in and clips in.
and you put it back together and enjoy!
2015 BMW M///5 Comp. Package I Black Sapphire Metalic I Full Black Leather I Gruppe M Intakes I 3D Design Side Skirts I HRE FF01 I RKP Lip I IND Cosmetic Pkg I JB4 BETA I BMS Meth SS I MSR CP I Challenge SS Brake Lines I Challenge Diffuser I Undercover DP's I Dodson Clutch Packs I VRS GTS Tips I M Perf. Carbon Mirrors, Spoiler and Full Interior +++
698 WHP & 653 WTRQ (Corrected)
      12-18-2015, 02:16 PM   #3
drbru
99
Drives: f10 m5
Thanks mate, so your suggestion is to take the whole diffuser off and not just the centre piece?
Dcara9.00
      12-21-2015, 11:09 AM   #4
Speed808Ix
Speed808Ix's Avatar
69
Drives: F10 BMW M5
You have to take the whole thing off, you cant just take the center off.
      12-21-2015, 09:08 PM   #5
evilb
evilb's Avatar
167
Drives: McLaren MSO 570S, 18 Raptor
I just replaced my center diffuser without removing the whole thing, so yes, it can be done. I used a bondo spreader and some nylon panel tools on each clip, one at a time.
Brad
2016 McLaren MSO 570S | 2018 Ford Raptor | @alpha7even
      12-24-2015, 11:11 AM   #6
Speed808Ix
Speed808Ix's Avatar
69
Drives: F10 BMW M5
Brad
Yeah I didnt want to snap off the re diffuser and be really pissed so I took it all off haha
      12-24-2015, 11:58 AM   #7
evilb
evilb's Avatar
167
Brad
In hindsight I'm sure your method was easier
      03-25-2016, 06:56 PM   #8
hybrid_eg
hybrid_eg's Avatar
852
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
thought i'd comment.. just did this last night in under 15 minutes the other night with BMW Motorsports piece..
Gentleman Jack on Rocks is optional
I used a panel removal tool to remove 4 plastic clips holding the center section of diffuser. In the middle you have three heavy duty bolts, will need star impact socket to get them off and little bit off pressure as they have thread lock.. Once hardware is out, simply wiggle the unit down and inward towards front of the car to slowly release plastic tabs holding it to upper section of diffuser.. (painted part).
The OEM unit fit like a glove, align it all back together and reinstall the hardware.. I WOULD RECOMMEND GETTING NEOPRENE BLACK WASHERS for heavy duty bolts so you dont have direct bolt to carbon contact..
Appreciate 2
M5Rick59842.00
      04-05-2016, 12:16 AM   #9
apexlocator
243
Drives: 2014 M5
What size were the torx bits?
      04-05-2016, 09:03 AM   #10
Speed808Ix
Speed808Ix's Avatar
69
Drives: F10 BMW M5
Should be a t10 if I remember correctly
      04-07-2016, 11:47 PM   #11
apexlocator
243
Drives: 2014 M5
Well just installed today....perfect fitment, about 20 minutes. ...T27 bit for me.
      04-27-2016, 08:33 PM   #12
///PDDS
///PDDS's Avatar
11
Drives: 2016 M5 Comp
T27 indeed. Took me about 20 mins also. I had to use a nylon prybar to unclip the diffuser, took some force actually. The CF diffuser clipped in like butter though.
2016 M5 Singapore Grey ZCP| Dinan Stage 2 | RPi GTM | STiR+ALP | OEM CF Diffuser | BlackVue 1CH | Coded Tricks
      09-17-2016, 09:30 PM   #13
Zubek
Zubek's Avatar
49
Drives: BMW
T27 and a little bit of patience is enough. I changed mine myself on the driveway. Actually I did it twice. Once with plastic diffuser and second time with the carbon fibre one.
      12-04-2016, 05:07 AM   #14
KFERI
16
Drives: 2012 F10 M5
Really stupid question, I just received a genuine M performance centre rear diffuser, was wondering if this part comes with any clips or bolts. Can I install it if i don't get the optional washers or heavy duty bolts and just use the parts that will come off the car from the stock rear diffuser. As I only received the carbon diffuser and nothing else.
      12-07-2016, 05:37 AM   #15
drbru
99
Drives: f10 m5
yes you can
      12-09-2016, 02:17 PM   #16
Blkthght
28
Drives: 2015 F10 M5 CP Singapore Grey
If you care about re-selling your diffuser one day, then take the 15 or so minutes and go to home depot and purchase the nylon washers. They prevent you from scratching the carbon fiber finish. This is a no-brainer actually.
      12-11-2016, 01:53 PM   #17
KFERI
16
Drives: 2012 F10 M5
Thank you for the feedback I'll def be getting the nylon washers
      12-13-2016, 10:29 AM   #18
Kritz
Kritz's Avatar
Drives: 2020 X3MC
Installed my M-Performance diffuser yesterday. It was a pain getting the middle portion off. I had to pull the entire diffuser off the bumper to pull apart the middle section. Looks good though.
2020 X3MC - current
2016 Porsche Cayenne SE-Hybrid
2016 X5 Imperial Blue
2013 M5 Azurite Black
      12-30-2016, 12:34 AM   #19
DesertEagle50
Admiral General
DesertEagle50's Avatar
13
Drives: 2013 F10 M5 FB
2013 BMW M5 F10  [10.00]
2010 BMW M3 E92  [10.00]
Very nice, looks so much better than stock.
Those who sacrifice luxury for fuel economy deserve neither - Ben Franklin
      12-01-2017, 10:21 PM   #20
chrisho68
90
Drives: AW/SO F10 M5
Thanks for this easy DIY. Did it tonight. Just like everyone said T27 torx for 3 screws in the front. 4 tab anchors (2 each side) and then 5 plastic tabs on the very rear portion. I'd suggest using a trim removal kit like "hybrid_eg" has pictured. I got this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 (don't worry, not an affiliate link)
Will prevent potential damage to the remainder of the diffuser. Got some silicone washers for the torx screws. Did everything in reverse and we're good to go. Will post some obligatory pictures tomorrow, did this tonight in the garage and lighting terrible.
      02-04-2018, 08:32 PM   #21
Madvillain
161
Drives: lada
where the heck did u find this plastic one and for how much??
      02-13-2018, 08:46 AM   #22
k3silk
k3silk's Avatar
147
Drives: 11 M3 & 14 M5
+1 Im looking for one also I don't want to bring carbon on the outside of the car.
m5post
