Underboost/boost leak turned into overboost after DP install?
12-15-2015, 02:28 PM | #1 |
90
Rep 115
My boost target was always lumpy in my logs and the actual boost was always a couple psi below that curve. Now, with downpipes, the boost curve is flat, but I am overboosting by a lot and don't want to hurt the car. It then seems to correct itself as I shift into 4th. I made sure the vbands were clear of the wastegate arms, why would this be? Running Roc Euro DCI, MHD, VRSF downpipes.
Original: http://datazap.me/u/bdefiori/vac-lin...=0&data=2-4-21 After downpipes: http://datazap.me/u/bdefiori/downpip...=0&data=2-4-21 Any help is much appreciated |
12-15-2015, 07:53 PM | #2 | |
BimmerPost Supporting Vendor
1334
Rep 1,701
Drives: Slot Machines.. Keep Taking $
12-15-2015, 08:32 PM | #3 | ||
51
Rep 719
Your band clamp is preventing the waste gate arm from moving
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
12-15-2015, 08:58 PM | #4 | |
90
Rep 115
Here's another I just took today after flashing down to Stage 1 base. Starts and ends well, but the middle has another spike and throttle closure. http://datazap.me/u/bdefiori/51-down...=0&data=2-3-20 |
12-16-2015, 12:35 PM | #5 | |
1334
Rep 1,701
Looks like you still have a minor issue. Make sure the WGs move freely. |
12-16-2015, 12:55 PM | #6 | |
90
Rep 115
What is there now? Solenoids? About throttle closures on a one size fits all map, I guess I'll have to upgrade to a custom map soon |
12-16-2015, 01:38 PM | #7 |
90
Rep 115
Update: So when started, the actuator rods take about 3-4 seconds to close the wastegates to ~50% (this can be seen by the eye). When revved, both banks on the monitor module on my tablet show ~80% closure, but there is no physical movement/change in the actuator rods. Since the solenoids fail at an open state, I doubt its the solenoids (unless they can fault to closed). Vacuum canisters are holding vacuum as well.
When the car is turned off, the rods immediately move and open the wastegates, so the wastegates aren't "sticky". |
12-16-2015, 02:05 PM | #8 | |
1334
Rep 1,701
12-16-2015, 02:54 PM | #10 |
90
Rep 115
Update: flashed to stock and logged. My old stock log showed underboost. Now, my NEW stock target boost is about where my OLD stock actual boost was, and my NEW stock actual boost is about where my OLD stock target was. WTF
Old (leaky): http://datazap.me/u/bdefiori/stock?log=0&data=2-4-21 New (over): http://datazap.me/u/bdefiori/stock-w...=0&data=2-3-20 |
12-17-2015, 05:39 PM | #12 |
Joint Chiefs of Staff
4920
Rep 115,999
