Budget upgrade advice
12-13-2015, 04:09 PM | #1 |
Rep 19
Hi all,
I've been reading about ugprading the stock system for some time, but i still can't decide which way to go. Because of my location, the upgrade options differ from others, so i'll just list them. Currently, i have the stock 6 speaker system (under seat woofers, door speakers in front and rear parcel shelf speakers), so the sound isn't great. I have the following options: - Logic 7 complete upgrade (13 speakers plus amp) - aftermarket speakers and amp (my current thought was Focal speakers with a JL audio JX360/4) From what i've read, the Logic 7 is a great surround system, but it has its limitations, and it isn't very cheap, plus all the coding and installing. The most preffered upgrade would be the Gladens and Mosconi, but they are way out of my budget, so i started looking for alternatives. The JLAudio JX360/4 is curently on offer and i can buy it new for ~150 euros. But i don't think it has differential/balanced inputs. Can this be a problem? Can it be solved by adding a processor between the car and the amp? I am seriously considering this because of the price, it looks like a good deal. The speakers i was looking for are the Focal ones made for BMW. IFBMW-S for the front and the dedicated subwoofers. I've had Focals and i still have ones for home audio and i like their sound. What do you think? Thanks. |
12-13-2015, 05:45 PM | #3 |
Rep 19
Thanks! I've gone through the links you mentioned, unfortunately most of the components there are US market-specific.
In europe, or at least where i live, rainbow, jl audio xd series, sws subs, cleansweep can not be found. And even if i manage to get them, the price would be too high. The logic 7 complete system is around 700 euros. So i was looking for an alternative at around this budget. The gladen and mosconi go around 900-1000 euros. That's too much, although i'm sure that they're great. The only reputable brands i can find here are: Speakers: focals (bmw ifbmw-s, krs100 and subs) dls (upi4, mc4.2, rc4.2, c4), audison prima comps, helix, match and mbquart. And the amps: Audison, dls, focal, helix,JL audio jx series, match and mbquart. Let's say i can even get something from us stores with the help of someone, but the budget would have to be around 750$. I would avoid the processing equipment (cleansweep, ms-8), because of the cost and because i could get help with coding to hi-fi. Any advice in the current situation? Thanks again. |
12-14-2015, 07:52 AM | #5 |
Rep 19
I've ordered the Focal KRS100 as the first step for upgrade, gladen/mosconi/jehnerts are too steep for me. The sound from the stock door speakers is just awful, it's like they reach a resonance frequency and start hurting the ears if the volume is a little louder.
With the focals i hope to solve this problem for now. The next logical step would be an amp (along with the hifi coding), what do you recommend? Also, if you have a recommandation for the woofers, please tell. For the amp, i was thinking, with a little luck, maybe a JL Audio XD600/6 and for the woofers the Audio System AX08, which i can get at a decent price. In the end i hope to get a better sound than a logic 7 system and that i've not wasted the money. Do you think it's a decent configuration? |
12-15-2015, 03:56 PM | #6 |
Rep 43
Hi Paul, i have the Focal KRS 100's.
They are amped by a JL XD500/3, which also powers underseat sws-8's. You say you'd like to avoid processors (cost), but bear in mind that the bmw head unit output is eq'd for non-tweeter speakers, unless you get it coded for hi-fi. Processors like the Audison Bit Ten will deal with the headunit, giving you a non-eq'd signal, as well as doing the clever time-alignment stuff. The Focals are very good, but will need a decent amp and some support from the underseat area to really come alive. Would be wise to fit Dynamat to the doors too, while you have the cards off. |
12-16-2015, 07:11 AM | #7 |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
12-26-2015, 12:38 PM | #8 |
Rep 19
Thanks for the replies.
The Focals have arrived and i've already installed them on the base system. The sound is better because of the tweeters, but i feel it lacks the drive of a more powerful amp. So, JK330i, you were right. Being the holidays, i've cut the budget for the JL amp and went, at least for a time, for an OE Hi-Fi Amp and the OE Hi-Fi speakers. They were at a good price and i couldn't resist. So it's basically going to be a Hi-Fi system with the front mid and tweeters from the Focal KRS100 kit. I checked the car's wiring and the links provided here by ctuna and others and understood how the system is wired. All the speakers and inputs are going to be pretty straightforward. The only question i have is where to connect the positive cable of the Hi-Fi Amp? The cable provided by the person who sold the amp doesn't have a fuse and i don't know if it should have. Also, i really don't want to risk to connect it straight to the car's battery with no fuse. Can someone please tell me how the amp is connected to the battery in the OE Hi-Fi system? I'll be back with some photos. Thanks. Last edited by paul_e88; 12-26-2015 at 12:44 PM.. |
12-27-2015, 10:54 AM | #10 |
Rep 19
Well, i've already bought the amp, so it's too late.
I'll replace it later, but for now, can anyone help me? Thanks. LE: attached photos with the base subwoofer vs Hi-fi subwoofer and the Focal midrange and adapter. Last edited by paul_e88; 12-27-2015 at 11:12 AM.. |
