2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics DIY and Coding Discussions E-Sys flashing with "hwDeinstall" and "hwInstal"
      12-13-2015, 05:28 AM   #1
cm048
Drives: BMW F10
Long story short.
I am swapping normal KOMBI with 6WB for F10 vehicle.
I need to flash new 6WB with the firmware same istep as the rest of ECUs.
I got red HWEL becuse this is retrofit, and the istep shipment of retrofit 6WB is not known. In order to flash, I know that I can get it done by creating SVT_soll
with "HW-IDs from SVTactual" and select only blFlash, swDeploy, cdDeploy, and ibaDeploy.
However, I would like to learn to take proper route with hardware replacement. Unfortunately detail information is very hard to find.
If I calculate SVT with the vehicle shipment istep without "HW-IDs from SVTactual", and proceed flashing with option "hwDeinstall" and "hwInstal".
Would this register the retrofit 6WB as factory original ?
Which option I suppose to select ? Everything except idDelete ?
I never use "hwDeinstall" and "hwInstal" before, and do not understand its exact purpose.
Can anybody helps explaining ?
Anybody has E-sys document which describes the meaning of hwDeinstall, hwInstal, blFlash, swDeploy, cdDeploy.... ?
      12-13-2019, 08:38 AM   #2
tyrystor
Drives: BMW E87 N47 engine
Hello,
Did you find the answer ?
Regards
2addicts
