JB4 Making High Pitch Noise
12-12-2015, 11:41 PM | #1 |
Rep 94
I have rewired the power to my JB4 to source 12V power from the boost solenoid. Everything is working properly but I've noticed a high pitch ringing noise coming from the solenoid valve now.
The noise is only noticeable when the car is powered on without the engine running (i.e. after locking/unlocking the doors, when turning IG power on, after shutdown). It goes away once the car completely powers itself down, at that time I also hear what sounds like a release of air coming from the solenoid valve. If I disconnect the solenoid valve the noise stops. I'm curious if anyone else has experienced this. |
12-13-2015, 09:32 AM | #2 |
28
Rep 583
I have the exact same noise. It is also noticeable when when accelerating hard.
Not present under normal driving conditions though, maybe because the JB4 isn't "working" at that point?
JB4 G5 ISO FF | BMS Performance Intake | BMS Wheel Spacers | VRSF Catless DP | Red CYBA Scoops | Supreme Power Lowering Perches | VRSF Charge Pipe | VMR 810 19x8.5 ET35 19x9.5 ET33 | Michelin PSS 235/265 | BMS CDV | BMS Clutch Stop | 4'' Tips
12-13-2015, 11:44 AM | #3 | |
Rep 94
Glad to see someone else with the same experience. Maybe it's normal. The JB4 should still be "working" under light throttle conditions because in ISO mode the JB4 has full control of boost. That's something I forgot to mention...my JB4 is setup as ISO boost control. |
12-13-2015, 12:22 PM | #4 |
602
Rep 2,703
Drives: 2009 335i - Sport PKG
check for oil leaks and Rear main seal
12-13-2015, 01:15 PM | #6 |
Joint Chiefs of Staff
4920
Rep 115,999
Might just be time for a new boost solenoid. Changing the default wastegate position setting within the interface may also help.
Mike |
12-14-2015, 11:02 PM | #7 | |
Rep 94
12-15-2015, 09:58 AM | #8 | ||
28
Rep 583
12-31-2015, 08:23 PM | #10 |
82
Rep 604
Now that ive reread the OP, I hear the high pitched noise for a while as well, and then the car farts and all goes away when it completely shuts down.
Never figured it would only happen with the jb4. |
01-01-2016, 04:19 PM | #11 | |
Rep 94
