RB PCV Valve leaking pressure? Anyone else?
12-11-2015, 06:57 AM | #1 |
92
Rep 709
My car has been making a whistling noise at low RPMS for about a month. I finally had a chance to bring her to my mechanic to see what was going on.
The problem was found to be a leak in the PCV valve. I was really surprised to hear this since I have been using the RB PCV valve only for the past 10-15k miles. I thought this was supposed to be an upgraded piece over OEM to prevent this sort of issue. I am conflicted regarding chalking this up to a manufacturing defect and obtaining another RB PCV valve or using the OEM one (I still have mine). Any thoughts? Anyone else have the RB PCV valve fail on them? Some quick background info: FBO (except inlets), PTF protuned 93 octane, turbos replaced under warranty 1 year ago. |
12-11-2015, 01:56 PM | #2 |
133
Rep 4,764
Have had rb pcv for a bit over a year. No issues. Have you contacted Rob directly to see what he thinks? Early on in the product life, I think people were having install mishaps with using the oe rubber ring. not sure why it would work fine for that many miles and develop an issue. See what Rob says.
12-11-2015, 02:22 PM | #3 |
92
Rep 709
I emailed Rob a little earlier. He states that of the thousands he's sold, there hasn't been a single issue thus far. I trust his word. It also doesn't make sense to me for the PCV valve to fail...
However, I don't think the problem is an install issue. It doesn't make sense for all this to occur after so much time has elapsed. I will investigate further. |
12-11-2015, 09:54 PM | #4 | |
Zeed
17
Rep 561
12-12-2015, 01:11 AM | #5 |
40
Rep 623
I have had the RB PCV valve installed in my car for over 40K miles, if not more and not a single issue whatsoever. You might have just got a "bad apple" since Rob has to source these from the Toyota Supra and not sure who is still making the stock supra pcv valve that rob modifies....
[SIZE="2"]Crimson Red E92 335i M-sport 6-speed with MHD custom stage 2+ flash only , 40% E85/93 mix,+ HRE P40S wheels, KW Clubsport, M3 sways,+BMW performance CF Mirrors, BMW Performance CF deck lid spoiler,+ CF interior trim, p3 vent boost gauge,+ LUX angel eyes (11.73@124mph on street tires)
12-12-2015, 01:29 AM | #6 |
Objects in the mirror are losing
105
Rep 1,133
Drives: 2007 BMW 335i E92 AW/CR 6MT
Have had a friend who had one fail on his N54. It made a whistling sound on idle and turns out the sealant/seal failed. All you would have to do is reseal it yourself. We did it on his and he was good to go.
With that said Rob also mentions this item is known as serviceable if I'm not mistaken. Either way just fix it yourself easier than having Rob send you a new one. I'm sure he will if you really want him too though if you send the old one back. |
12-12-2015, 11:30 AM | #7 | |
387
Rep 1,571
We have never seen a bad or defective valve. We have had casual dealings with a few consumers over the course of 4 years and ~3,000 unit sales who think otherwise. Even though they represent a lowly .1%, and it is hardly worth the clarification- I can say with certainty that they were wrong about the valve via tests upon return. As stated via email (and above) this PCV Valve is the absolute best money can buy and I've never seen one defected. But at the end of the day- this is still a PCV Valve. It is not expected to last forever in application. They also can foul due to excess contamination, all engines and exposure rates are different. Granted they should last for 50k miles easily, but due to many things we can never control we recommend changing around 50k mile intervals. Much like that $175 oil change with premium engine oils, the $150 air filters, or the $125 spark plugs; they still will need changing at some point. This is simply a $40 maintenance item that installs onto an automobile engine, a much superior design over the OEM unit which is actually unavailable without buying a entirely new $400 valve cover. The biggest complaint we have seen or heard bar none has been broken PCV caps, which we can not control. Our RB PCV Cap sales have also grown quite a bit due to this. Next up is some oddly molded OEM cap castings, that at times can poorly fit the new RB PCV Valve. This is a very easy correction by only needing to do a minor clipping to the "finger edges" that position the valve in the cap. Using our CNC Billet machined RB PCV Screw-On Cap also avoids this possibility as well. Seldom thereafter is poorly seated valves or damage to the grommets. New grommets can be purchased from Toyota for around $6 if you need one. More on this below. None of the above were are the valve failing itself. NOTE: Several months ago we did change up the PCV Valve adaptation design to be more OEM like by using an O-ring and no longer require a separate grommet, it makes them a little easier to install and seat perfectly without much effort. As mentioned above some minor few did have to seem to have some grommet seating issues during installs (or grommet damage over time)- which this should eliminate. The email I have sent the OP was spot on and 100% accurate, never once has a valve failed to my knowledge to date. But at the same time, due to the fact that it is a maintenance item, if one does that just means it is time to replace it. Rob Last edited by Rob@RBTurbo; 12-12-2015 at 11:41 AM.. |
12-13-2015, 10:21 PM | #9 |
387
Rep 1,571
12-14-2015, 02:11 AM | #10 | |
69
Rep 310
Drives: 2007 BMW 335i M-Sport E90
Car has approx 80k miles on it. Cheers, |
12-15-2015, 10:10 AM | #12 |
654
Rep 946
12-15-2015, 01:47 PM | #15 | |
387
Rep 1,571
Thanks, Rob |
12-15-2015, 10:27 PM | #17 |
380
Rep 1,497
I had the same issue, Did u make sure you have the rubber gasket seal on the pcv around the end like the picture shows. When I replaced my valve cover and swapped over the rb pcv valve and such and ended up getting the whistle.. Searched and search. Re trqed the valve cover and all, nothing.removed the pcv valve and found out that when I swapped everything over, the rubber seal was still in the old valve cover. Put it in and problem got solved
bluemonstr54.50 |
12-15-2015, 10:43 PM | #18 | |
Something Danger Zone
41
Rep 257
My PCV valve did have some issues on my previous car, but it was a first round model & lasted nearly 20k miles. The one you sent back after that I didn't have any problem with other than when my car was deemed totaled and I couldn't get it back. I'll be ordering one soon again too as to help save my valve cover. |
12-16-2015, 06:45 AM | #19 | |
28
Rep 409
Edit: Missed that you covered this already, carry on!
2009 E92 335i M-Sport - MHD Stage One - BMW Performance Exhaust - BMS Oil Catch Can - CDV Delete - K&N Panel Filter - Arc Angel H8 bulbs - Gloss Black Kidney Grills - Painted Reflectors - VRSF Charge Pipe
12-16-2015, 08:21 AM | #20 |
387
Rep 1,571
The grommet that was used and pre-equipped on the older style RB PCV is PN 90480-18001. This version some tried to use the O-Ring AND the Grommet, which is not as intended. The Grommet can be harder to seat as well, for some.
(NOTE: NEWER Versions of the RB PCV Valve have OEM style adapters and O-ring, that yes come pre-equpped for hassle free install, as pictured above.) Just a reminder- PCV's are disposable maintenance items. If in doubt simply replace it. Thanks, Rob |
12-17-2015, 03:02 PM | #22 | |
387
Rep 1,571
Both work functionally the same. Thanks, Rob |
