Remote car starter?
12-04-2015, 08:11 AM | #1 |
Rep 4
Remote car starter?
Ive been looking into if it were possible to DIY a remote car starter. I have been researching and it looks like there are some plug and play kits out there. ( http://www.amazon.com/Idatastart-ADS.../dp/B00R1Y0FFI )
Has anyone done this and if so any advice or recommendations? I have a 2011 328xi automatic. |
12-04-2015, 09:59 AM | #2 | |
223
Rep 5,120
12-04-2015, 11:33 AM | #3 |
198
Rep 562
I just installed the ADS-BM1 along with compustar drone mobile and it's by far the best remote starter i've used. It's completely plug and play with zero wiring splicing required. Only took about 20 mins to install. The newer kits come with 2 long range remotes (one 2-way and 1-way remote) that's good for up to 3000ft.
The only thing you need to buy extra is the ADS-USB cable so that you can flash the ADS-BM1 module with the correct firmware so that it works with your specific vehicle. There are definitely other remote starters that offer more features but be prepared to splice into the cars existing wiring. With how finicky bmw electrical systems are, I wasn't willing to go this route. Since it's plug 'n' play, you can simply unplug everything and resell the unit if you ever sell your car. Last edited by siphor1989; 12-04-2015 at 11:41 AM.. |
12-04-2015, 11:50 AM | #5 | |
Rep 4
12-04-2015, 12:15 PM | #6 | |
198
Rep 562
No complaints with the unit so far. Starts up every time with either the OEM key fob, supplied remote, or via the drone mobile app on my phone. Takeover is easy as you just have to unlock the car and press on the brake. I purchased mine from a Canadian retailer in Toronto. |
12-04-2015, 01:12 PM | #8 |
198
Rep 562
12-04-2015, 02:14 PM | #9 |
156
Rep 443
siphor1989
I've read of users remote starting their car via key fob then driving off without the key fob in the ignition, basically having comfort access feature. Can you confirm ? I'm sure this feature alone would spark interest This same person also mentioned testing the security feature by leaving a window open and unlocking the door without the key fob and the vehicle did shut off. |
12-04-2015, 02:40 PM | #10 | |
198
Rep 562
The car MUST be unlocked via the OEM key, supplied remote, or via drone app or else the car shuts off as soon as the brakes are applied. |
12-05-2015, 07:58 AM | #12 | ||
379
Rep 2,365
Drives: 2007 E90 323i (Cdn)
Is your car auto or manual? What did it cost after labour? Having a hard time finding something that will work with 6MT
12-05-2015, 07:59 AM | #13 | |
379
Rep 2,365
12-05-2015, 09:30 AM | #14 |
tends to get irritable
202
Rep 798
We do these fairly regularly. Straight forward and non evasive. Typically paired with a remote and/or phone app (Drone). We just had a guy from your neck of the woods in recently with his X5.
AC Schnitzer/Eibach/M Performance/RaceChip/Compustar/Drone/BimmerTech/FireTV/Helix/Dynaudio/Micro-Precision/Jehnert/Audiomobile |
12-05-2015, 11:11 PM | #15 |
198
Rep 562
12-06-2015, 06:15 PM | #16 |
223
Rep 5,120
The only connections to the car are power, ground, 2 CAN wires, and 2 brake wires. It took a day or 2 the biggest problem being the lack of room in the dash. I ended up pulling out all the unused wires from the viper harness. Since the kibmw and dlpk use d2d that ended up being most of them. I'm not concerned about going back to stock at this point because it would be too much effort and I don't have all the pieces .
12-06-2015, 10:08 PM | #18 |
202
Rep 798
There is not.
02-18-2016, 04:00 PM | #19 | |
Bob Saget
355
Rep 2,229
If that's the case. I am buying this now. Do you have a video? Also how is it plug and play? Does it plug into obd-II?
In memory of Robert E. Flynn (AR)
02-21-2016, 09:27 AM | #20 | |
198
Rep 562
The remote starter comes with a harness that plugs into the cars existing connectors. |
02-22-2016, 09:03 AM | #21 | |
Bob Saget
355
Rep 2,229
Can you also extend the 40 seconds to something longer? What were all the modules you had to buy?
02-22-2016, 10:07 AM | #22 | |
198
Rep 562
You can easily program the remote starter to extend the takeover procedure. I bought the idatastart BM1 kit and the only thing extra you need is the usb adapter to program the module itself. If you want the drone mobile app capabilities, then you need to get the drone add-on module. |
