2010 2011 BMW 5 Series Forum F10 F10 535 - AFE Intake vs BMS - Which one is "better"? |
12-03-2015, 11:12 AM | #1 |
602
Rep 2,197
I understand that neither intake will produce any real gains. I already have the BMS intake and am only partially satisfied. It doesn't provide the growl at WOT that I had with intakes on my other BMW's, and it has no heat shield or protection against heat soak from the hot engine back. Wondering what is the general consensus on the AFE intake?? I know it is pricier, but if you could pick one up slightly used, is it worth the money?
Bake
2011 Alpine White on Black 535i M-Sport 2013 Space Gray on Fox Red M3 Vert |
12-03-2015, 01:17 PM | #2 | |
9163
Rep 14,521
i'm just kidding! being in a sealed enclosure i'm sure it'll be really quiet and you won't have the issue of hot engine temps with an open filter.
~F90Conversion~21"3Piece Forged AvantGardeWheels~KWV1Coilovers~CQUENCE slotted/drilled rotors~GoodridgeStainlesslines~MeisterschaftQuadEx haust~Akrapovic 4"tips~VRSF DP~VRSF CP~TurboSmart BOV~K&N filter~CarbonFiberExteriorComponents~GladenAlphaCo mponents~MatchUp7BMW~Punch P300-12T~ Follow me on Instagram: lsturbointeg |
12-03-2015, 11:24 PM | #3 |
42
Rep 168
What a coincidence, I was just doing some research on this last night. More on what I was reading :
http://www.bimmerfest.com/forums/sho...d.php?t=716477 To make a long story short, I'd side with BMS as far as performance gains are concerned. Not sure about the sound though. You could always run my set up |
12-04-2015, 02:34 PM | #4 | |
9163
Rep 14,521
12-04-2015, 07:33 PM | #5 |
56
Rep 244
I had not previously seen the dynos of the BMS intake. I bought an AFE intake and did a before and after dyno, going from a K&N drop in filter to the AFE intake. http://f10.5post.com/forums/showthread.php?t=987089 The BMS intake looks to perform much better than the AFE above about 5K.
Mike
'04 330i ZHP '11 535i |
12-08-2015, 09:00 PM | #7 |
602
Rep 2,197
After reading that write up on the BMS I will keep that, but still wish it had more intake growl. Don't really want more exhaust sound, I am happy with my M Performance mufflers.
Bake
12-11-2015, 02:58 PM | #8 |
Joint Chiefs of Staff
24317
Rep 191,031
If you want more sound, consider downpipes or full exhaust system
12-11-2015, 04:03 PM | #10 |
24317
Rep 191,031
They should not but it is not a 100% guarantee
The better the brand, the less likely to get a CEL I strongly recommend Evolution Racewerks catted downpipe
12-12-2015, 10:23 AM | #11 |
Dream crusher
984
Rep 2,421
I literally took off my entire stock intake filter and drove only a few blocks to see if the sound changed and nothing. So either one is not going to give you the growl. A DP will, however there is a "rasp" that comes with the growl that I'm becoming less and less a fan of. I think your best bet is an exhaust system.
535i MIssion Performance, PS2, Helix HPFP Kit, Wagner FMIC, Spec 3 clutch, Steel SMF, Wolf Racing CP, UUC SSK, GFB dv, SprintBooster, Custom Dynomax Exhaust, M5 Sways, Eibach OE Springs, Koni Sports Adjustable, Custom Short Ram CAI
IG: @bmwdoubles |
12-12-2015, 07:24 PM | #12 | |
24
Rep 330
Just wanted to say that my friend installed a pair of stock M5 mufflers on his 535 and it sounds really nice. More aggressive than the stock mufflers he had. They don't come cheap though. Something to consider. I did the DP thing and hated the smell. |
12-12-2015, 11:20 PM | #13 | ||
Rep 45
12-14-2015, 12:13 PM | #14 |
602
Rep 2,197
Guys, I already have M Performance mufflers installed and the sound is very similar to M5 mufflers (I have compared the two side by side). Was still looking for additional grunt on the intake side. Doesn't sound like I am going to get it, and not interested in the rasp from a DP. I will likely just leave well enough alone.
Bake
12-14-2015, 12:37 PM | #15 | |
42
Rep 168
12-27-2015, 09:33 AM | #16 | |
35
Rep 414
Mike F
12-27-2015, 08:54 PM | #17 |
181
Rep 354
Drives: 2017 F80 ZCP MW/SO
Take the midsection resonator out , I went with AFE great customer service!
Current: 2017 F80 ZCP MW/SO @EnzoRacing PTF BM3 STG 2 GTHaus Meisterschaft GT2 Exhaust SSR Intakes
Swift Springs @drivingwithbenny |
