WTB : HVAC Blower Motor E90 2006
12-03-2015, 10:43 AM | #1 |
Rep 83
Hi,
As title says, id like to get a HVAC blower motor for E90 2006 (330)... Mine squeaks and drives me nuts. Wd40 solves the problem for couple weeks and then problem returns. Thanks! Stoppy |
12-07-2015, 01:58 PM | #3 |
2341
Rep 3,543
If you can get it lubricated with some real grease (not wd40) it may help for a bit longer than just few weeks.
Ideally you should take it out and lubricate properly so you don't have grease smell coming through your vents. Just a suggestion before you buy new. Cheers |
12-08-2015, 10:44 AM | #4 |
60
Rep 965
Drives: '14 328xi sport line
Garage List 1981 Fiat 124 Spider [0.00]
2014 F30 BMW 328xi [0.00] 2006 E90 BMW 325i ( ... [0.00] 1988 Audi 90 Quattr ... [0.00] |
These things aren't really serviceable, they're pretty closed. I caved and bought a new one at the dealer years ago.
12-08-2015, 11:44 AM | #5 |
57
Rep 273
Drives: 335i, 330i, 335xi, 6MT sport
You need to get something thicker than WD-40 in there. Take the blower out, take the motor/fan out of the housing and lube up both of the bushings with whatever engine or gear oil you have a few drops of. Make sure it gets plenty of time to absorb.
It smelled like gear oil in my car for a week afterwards, but the squeak has been gone for over a year. |
12-17-2015, 05:32 PM | #6 | |
Rep 83
What lube did you use? If I do it, I want to make sure I dont have to do it again weeks later. Thanks! |
12-21-2015, 09:04 AM | #7 |
57
Rep 273
I'm not sure exactly what I used. it could have been some Amsoil 140-EP90 leftover from a Jeep liberty rear diff 11 years ago, or the Redline I used in my rear diff last year.
With the right Torx bit you can remove the motor from the assembly to get access to the other bearing you can't see. |
12-23-2015, 06:03 PM | #8 | |
Rep 83
Stoppy |
