2010 2011 BMW 5 Series Forum F10 LED Fogs / Reverse Malfunction Even After Coding |
12-01-2015, 10:13 PM | #1 |
38 57 6.5, -77 8 44
Rep 16
Drives: 2020 X3M Competition
It seems we're having an issue coding my F10 to play nice with LED H8 fog lights and LED 921 reverse lights. I just sent back the last "CanBus friendly error-free" fogs and will be upgrading to a brighter set with a separate error-free load resistor adapter. I'm not sure if that's going to work with the coding done to the fogs already, I can't put an in-line adapter in place for the reverse lights due to their mounting location, and I don't know what the codes were that were meant for the fog lights, but the reverse lights are also showing a malfunction on the dash.
Can anyone who has successfully installed aftermarket fogs and reverse lights tell me what the proper code is to stop cold and warm checks through CanBus? I had a code I thought would work but it was for an F30. I'm not the coder nor do I have any input when it comes to this, but if I can find the correct code necessary for those who have used non "CanBus friendly error-free" bulbs and got them to code-out without showing any malfunctions, I can provide that to the shop doing the coding for me. Thanks in advance! Lots more coding questions incoming but will ask those separately after searching to see if the answers are already here - tried that with this but couldn't find any solid answers....
BETWEEN SUBTLE SHADING
AND THE ABSENCE OF LIGHT LIES THE NUANCE OF IQLUSION |
12-05-2015, 11:08 AM | #2 |
38 57 6.5, -77 8 44
Rep 16
Everyone has working LED fogs and reverse lights? No help with my situation?
12-12-2015, 08:47 AM | #4 | |
38 57 6.5, -77 8 44
Rep 16
I bought resistors for the fogs but they haven't even arrived yet! They worked without them, and I can't put in resistors for reverse lights with the limited room and mounting location of the bulbs in the harness, so I guess I have to keep trying to find true "error free" reverse lights until I find one that actually works....
12-12-2015, 09:57 AM | #6 |
38 57 6.5, -77 8 44
Rep 16
Yes, the orange triangle on the bottom left of the cluster and then under Vehicle Info on the Nav screen shows the error.
12-12-2015, 07:35 PM | #8 |
Rep 25
For the front fog lamp I would suggest;
Quite expensive, original from BMW, around $180 each. It required a coding at module FRM3090. Compare to bulb retrofit, it is not only beautiful but also actually works with proper light pattern. |
12-12-2015, 11:26 PM | #9 | |
38 57 6.5, -77 8 44
Rep 16
Damn.... I was interested in those but read somewhere they were way more expensive than that, so I gave up looking into part numbers! That's much better than what I thought they were. I'll get those after I put in more go-fast parts in a few months, thanks for the suggestion!
03-09-2016, 02:15 PM | #10 |
Rep 5
ebay Item: 172080831553
for fogs I bought a kit with resistors included. eBay item number:172032326882 these are 7.5W is not a bright white... if you can find 35W are better. for more DIY for F10 model join this group: BMW 5 Series (F10) UK |
03-11-2016, 02:43 PM | #12 | |
55
Rep 80
Drives: 2019 BMW X7 xDrive50i
Relatedly, I have an F10 M Sport pre-LCI and I've read that the fog lights take H11 bulbs. 2 questions:
2019 BMW x7 xDrive50i in Phytonic Blue on Black -- 22" 756 Wheels 2015 BMW x5 xDrive35i in Mineral White on Canberra Beige - (sold) 2013 BMW 535i M Sport in Titanium Silver on Black - (sold) 1999 BMW z3 2.3 in Space Gray on Black - (sold) |
03-13-2016, 11:54 AM | #13 |
98
Rep 305
PreLCI MSPort Fogs, H11 35W HID Works with capacitors, no coding needed
PreLCI Reverse Bulbs, I Used Generic R5 LED, no thing else, no coding needed LCI Msport Fogs, ditching the LED oem set and going HID/projector soon, LED ones are for sale. LCI Reverse Bulbs, H21W(socket Bay9S), or change the socket over to whatever you want, T10/T20 etc. Installed with 6ohm 50W resistors on each, no error, no coding required. I believe the same applies to PY24W front signals on LCI models. PS H8 & H11 are basically interchangeable. |
03-14-2016, 11:57 AM | #14 | |
55
Rep 80
I wish I could afford an LCI F10 with all the options I want. Then I'd have the right fog lights (and adaptive LED headlights).
03-14-2016, 01:23 PM | #15 | |
98
Rep 305
These are the ones I got for my prelci: http://store.ijdmtoy.com/Plasma-High...s-p/10-326.htm |
03-16-2016, 11:36 AM | #16 | |
55
Rep 80
Do you have a link to the fog light bulbs you bought?
03-16-2016, 07:27 PM | #17 | |
98
Rep 305
http://www.e90post.com/forums/showthread.php?t=338009 |
03-17-2016, 02:10 PM | #18 | |
55
Rep 80
03-17-2016, 03:08 PM | #19 |
98
Rep 305
03-17-2016, 03:58 PM | #20 | |
55
Rep 80
And no, haven't purchased the HID kit yet.
