11-25-2015, 11:01 AM | #1 |
Rep 11
Jb4 + mods thoughts
Last night I finally got around to installing my jb4 on my 2012 n55 PWG & all I can say is great job bms they live up to the expectations again. I'm running er dp, bms intake, er cp , jb4 & this set up just pulls for days. Last night I was pushing so much power my oem run flat got a huge bubble on the side wall you know what that means is coming next... Anyways for all you guys runnin e85 mixtures on PWG do you have any tips or advice before I start loading up a couple gallons in my tank?
Thanks |
11-25-2015, 03:25 PM | #2 |
BimmerPost Supporting Vendor
24273
Rep 190,975
Agree Jb4 does a great job !!
Why no intercooler?
11-25-2015, 05:44 PM | #3 |
4920
Rep 115,999
Start with about 25% E85 and go from there..
E85 Use Models equipped with the pneumatic wastegate & flex fuel connector may experiment with up to 40% E85 mixtures. Some cars tolerate E85 and some do not. Cars that do not tolerate the mix will "buck" or "miss" at full throttle. In some cases map 7 can be used on the E85 mix and in other cases map 2 is the highest that can be used. It's best to start slowly and work your way up in terms of aggressiveness when experimenting with E85 mixtures. |
