11-23-2015, 12:39 AM | #1 |
50
Rep 208
Headlights Help
I'm in need of some brighter headlight bulbs for my car because the stock bulbs aren't cutting it at all. HIDs isn't an option since I have reflector headlights so I was wondering if LED bulbs would be appropriate to install into a reflector housing.
I found a set from XenonDepot at this link: http://www.xenondepot.com/H7-LED-hea.../h7-led-hl.htm As always all help is appreciated! |
11-23-2015, 01:25 AM | #2 |
Stark und Frei
48
Rep 155
11-23-2015, 07:13 AM | #3 |
8245
Rep 16,088
LEDs are expensive and require external ballasts or you'll get a 'no bulb' warning. These are are a higher lumen drop-in replacement for stock halogens:
http://store.candlepower.com/osraulhiouh7.html It's the only H7 that has higher lumen output. Other 'performance' H7 may have higher color temperature but they aren't any brighter than stock. |
11-23-2015, 08:22 AM | #4 |
118
Rep 1,668
Would still be interested in knowing what the LEDs look like.
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
11-23-2015, 10:13 AM | #7 | |
50
Rep 208
11-23-2015, 12:44 PM | #8 |
8245
Rep 16,088
11-23-2015, 07:46 PM | #9 |
32
Rep 185
Drives: 2017 X3 35i X Drive M Sport
I replaced the stock bulbs in my previous E90 with Silverstar ZXEs and they were only slightly brighter than stock. I have heard good things about the Osram Nightbreakers but don't expect miracles. Keep in mind that the brighter the bulb the shorter the lifespan.
11-23-2015, 08:09 PM | #10 | |
773
Rep 1,113
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD 2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive |
