Logic 7 vs Individual Subwoofers
11-21-2015, 10:49 AM | #1 |
123
Rep 604
Does anyone know the ohms that a Logic 7 subwoofer runs at and the ohms used by an Individual subwoofer?
What is the sound difference between Logic 7 & Individual subwoofer? Thanks in advance! Last edited by Ao1; 11-22-2015 at 12:51 PM.. |
11-21-2015, 03:07 PM | #2 |
123
Rep 604
To answer my own question after reading up it seems that Logic7 OEM woofers are 4 ohms (70W), the HiFi woofers are 2 ohms (40W)
Individual woofers are 7 ohms (based on a consensus of posts) |
11-22-2015, 12:27 AM | #3 | |
57
Rep 272
FBO , MHD , tuned
11-22-2015, 03:37 AM | #4 |
123
Rep 604
I've got the BimmerTech amp. Individual mid range and tweeters and Logic 7 subs.
I've come across some Individual subs, but think it may be a mistake to fit them as the ohms are different. I don't think the Individuals are that much better than the Logic 7's and if the difference in ohms are taken into consideration maybe they will sound worse. The BimmerTech amp is: at 4 Ohms 8 x 55 Watts / 110 Watts at 2 Ohms 8 x 70 Watts / 140 Watts As far as I can tell the Individual speakers (excluding the subs) are 4 ohms. SWS-8X (4 ohms) would seem to have been a better choice over the Logic 7 subs (4 ohms) or Individual subs (7 ohms) Last edited by Ao1; 11-22-2015 at 12:51 PM.. |
11-23-2015, 02:30 AM | #5 | |
Rep 114
1)the BIMMER tech amp(helix match pp82dsp) 2)individual front/rear mid-range and tweeters(acquired) 3) individual underseat subwoofer (acquired) 4) individual dash speaker(acuried) Not sure if this will work out well? Any input/suggestion will be greatly appreciated!
2010 E91 320D LCI ALPINE WHITE, PERFORMANCE POWER KIT, PERFORMANCE BRAKE KITS, OEM M3 MIRROR WITH POWER FOLDING OPTION, M AERO PACKAGE, PERFORMANCE FRONT BUMPER CARBON FIBER LIPS N REAR CARBON FIBER DIFFUSER, FULL CARBON FIBER INTERIOR TRIM KIT, KONI 1130 W/ H&R SPORTS SPRING,
EISENMANN RACE EXHAUST, OEM 19" WHEEL STYLE 230 & M225 |
11-23-2015, 07:23 AM | #6 | |
300
Rep 3,969
Mobridge DA2 > JBL MS-8 > ARC XDi 600/4 > JBL Gti 408 Mids & Vifa OT19 Tweeters; PG Ti2 1600.5 > Morel HCW-10 & IDMax 15
11-23-2015, 08:00 AM | #7 |
123
Rep 604
^ I asked Nelson@BimmerTech and he said the Bimmertech amp could run with the Individual subwoofer, but I don't know if he realised it was 7 ohms.
Currently I have Logic 7 subwoofers fitted. I did try one of the Individual subwoofers by connecting it up but without fitting it and it seemed a bit louder than the Logic 7 woofer, but this was not a fair comparison as the Individual amp was not fitted. I really want to fit the Individual subwoofers, but not if it is going to cause damage to the BimmerTech amp or detract from the other Individual speakers running at 4 ohms. Last edited by Ao1; 11-23-2015 at 10:58 AM.. Reason: typo |
11-23-2015, 11:16 AM | #8 |
1911
Rep 13,103
To be technical if you measure Jehnerts they are 6.5
To be technical if you measure Jehnerts they are 6.5 ohms
There is a difference between impedence for a moving audio signal and the raw resistance as done in a resistance measurement and impedence. 4 ohm isn't going to hurt the amp . Last edited by ctuna; 11-23-2015 at 11:25 AM.. |
11-23-2015, 11:29 AM | #9 | |
123
Rep 604
(I'm not 100% the Individual woofer is 7 ohms. It's the best I could determine from reading dozens of threads on the forum) |
11-23-2015, 02:45 PM | #10 | |
300
Rep 3,969
11-24-2015, 07:32 AM | #11 |
123
Rep 604
Thank you. much appreciated. I've asked Bimmertech and await their response, but by the sounds of it I will be keeping the Logic 7's.
11-25-2015, 09:54 AM | #12 | |
238
Rep 947
I have my L7 woofers externally amplified at a true 70W RMS and there is a big improvement in bass and mid bass The impedance of these speakers will not make a noticeable difference, at least to the human ear (granted you have enough power at that impedance). I'm actually running my L7 subs at 8 ohms due to the amp I am using Last edited by matteblue3er; 11-25-2015 at 10:06 AM.. |
11-25-2015, 03:35 PM | #13 |
123
Rep 604
Bimmertech have confirmed the Individual subwoofers won’t get enough power, so one final question. The amp is:
at 4 Ohms 8 x 55 Watts / 110 Watts at 2 Ohms 8 x 70 Watts / 140 Watts The mid-range/tweeters are 4ohms. If I was going to fit SWS subs would I be better getting the 2 or 4 ohm version? Thanks in advanced. |
11-25-2015, 05:37 PM | #14 | |
300
Rep 3,969
david in germany729.00 |
11-26-2015, 03:38 AM | #16 |
Rep 114
11-26-2015, 03:41 AM | #17 |
Rep 114
Thinking about fitting the FOCAL pnp sub + match pp82dsp
11-26-2015, 10:36 AM | #18 |
300
Rep 3,969
Don't get the Focals. Read the comments of user DrRobert (spelling?). He spent $800 on those "subs" and didn't like them.
This application really cannot handle a "sub"woofer. There just isn't enough air space in the enclosure to support the large cone movement required to produce frequencies below 40-50Hz. Subwoofers also don't handle mid-bass frequencies very well. Keep in mind that the application needs to be able to play to a minimum of 200Hz, to meet the 4" speakers in the doors. So any driver that is made to be a "subwoofer" won't work well, because it doesn't have enough space to breathe properly, and it will suck at producing midbass frequencies. That's why the SWS-8 does not work well in this application, or any other driver that is built foremost to produce subwoofer frequencies. What this application is then best used for is mid-bass. We are talking 50 - 200Hz. There are plenty of BMW specific mid bass drivers that work, but the best feedback I have seen has been for Gladen and Jehnert (and I may be forgetting one or two since I have not been keeping up with new products). Some people are satisfied with the amount of bass from the mid-bass drivers, others end up installing a trunk subwoofer to fill in the low end. My recommendation is to get a good (proven) midbass driver in this application and then decide later if you need a trunk subwoofer or not.
11-26-2015, 01:17 PM | #19 |
1911
Rep 13,103
Jehnerts are the best mid bass underseats.
I would get a Jehnert 3 way kit with your 82 dsp. There are tuning setups for that already . I have heard Gladens are pretty good. If you are in England talk to this guy. http://www.e90post.com/forums/showthread.php?t=704363 Last edited by ctuna; 11-30-2015 at 12:28 PM.. |
11-30-2015, 12:05 PM | #20 |
Rep 43
I've recently had some kit fitted, namely Focal components and SWS-8's under the seats, driven by a JL Audio 500/3. Audison Bit Ten pulls it all together.
Its a sound quality system, and to me sounds very good. The SWS-8's do fall into a category of their own, in as much as they're neither sub or mid-range. That said, while i have no experience of Jenerts, i'm very happy with my system. If there is sub-bass in a track, you'll hear and feel it. If there isn't, you won't. By example, David Bowie "Ashes to ashes", and Lorde "White teeth teens". Bowie just sounds great, Lorde I can feel through my body, and the steering wheel. Same with Subtrkt. My point, in the right system, the SWS-8's sound great. I'll have a look for the Jehnerts, not seen them in the UK. Reading further back, i think the SWS are low passed at 150hz, Focals high-passed at the same. Could be wrong there, but cant be arsed to go out in the rain and plug in to find out. I probably will add a boot sub and amp, just to help overcome the losses with raised noise when on the motorway, etc. Last edited by JK330i; 11-30-2015 at 12:13 PM.. |
11-30-2015, 06:11 PM | #21 |
Rep 45
The only conceivable difference impedance makes (2 ohm vs 4 ohm vs whatever) is the power output of the amp. So long as your amp is 2 ohm stable, it will put out approximately twice as much power to a 2 ohm woofer than a 4 ohm woofer (Ohm's law). Impedance of a loudspeaker doesn't really have an impact on sound quality in and of itself.
Personally, I have the Match MS 8B-BMW.2 woofers for my underseats. They are 4 ohm and can handle up to 150W RMS. I like their sound a lot. They're also shallow enough to fit without spacers unlike the SWS-8. That said, you can't really go wrong with Gladen or Jehnert or anyone else. They're all good. I just have Match woofers because I also have the component set and I liked the fact that they have good sensitivity and high RMS power handling. Good price too. Also, bear in mind, some of the woofers have lower frequency ranges of frequency response than others. For instance, I would consider Jehnerts as more "midwoofers" than "subwoofers" due to their extended frequency response so make sure you know what you're buying. Generally speaking, a speaker with a narrower intended frequency response performs better within that range than a speaker with a wider frequency response. That's why 2-way and 3-way systems exist. You can't have one speaker playing too many frequencies. It's like the saying "jack of all trades master of none". Another reason I like my Match subwoofers. BACK ON TOPIC (actually answering OP's question): If you're going to be using the bimmertech amp (max RMS output of 70W at 2 ohms) I would recommend going with a 2 ohm woofer since you'll get the most power this way. For woofers to perform they really need as much power as they can get and it seems like the best you can do for that is use a 2 ohm woofer. As kaigoss mentioned above, if you could bridge the amp (not sure if this is possible), then you could have even greater output with two 4 ohm subs on 4 channels like so: If you can't bridge the amp then go for the SWS-8 since it's the only 2 ohm option. If you can, then go for whichever 4 ohm woofer you like best. Last edited by rambca; 11-30-2015 at 06:39 PM.. |
12-01-2015, 12:42 AM | #22 | |
Rep 114
http://www.m3post.com/forums/showthread.php?t=166476 Not sure about the true impedance for logic 7. Read somewhere on the forum that logic 7 subs are 4ohms? You might want to verify that with the experts on the forum!
