11-20-2015, 12:11 AM | #1 |
793
Rep 1,627
How reliable are our brake pad wear monitors?
Just reached 40,000 miles on my late build '14 435i and when I check the brake pad life I'm told that I have 70,000 miles left for front brake pads and 80,000 miles left for rear. Is this normal for the Msport brake pads or might something be wrong with the monitors? When the car was new it stated that I had 80K front and rear..Hard to believe that virtually none of the brake pads have been used with 40K miles of relatively hard driving.
M4 in MG | 6 MT
11-20-2015, 01:54 AM | #2 | |
497
Rep 902
Drives: 13' F30 385xi VNV Speed Custom
Garage List 2013 Mercedes SL63 ... [0.00]
2010 VW Tiguan 2.0 ... [0.00] 2015 Tesla P85D [0.00] 2014 Mercedes S63 AMG [0.00] 2007 Mercedes GL450 [0.00] 1967 Ford Mustang [0.00] 2013 BMW F30 335xi [0.00] |
13' 335xi, ACF Tuned, ACF Stage 3 Turbo Kit (67mm),PDU PI, ACF Stage 4 LPFP, M-Perf Brakes, AEM CM10 Meth/Nitro, CG DR-1 + VS-1 3.5" Turboback, AFe S2 CAI+Ram Scoop, ER Chargepipe, Wagner EVOII Comp. FMIC, Stop-Tech SS Brake Lines, BMS Sport Oil Cooler Valve+Spacers F10mm R15mm, 19" Bridgestone Potenzas, KW EDC Coilovers, CF Seibon Hood + CSL trunk. Track:Pagid Race Pads, Stop-Tech Custom Pads Front+Rear Racing Tow Hooks
11-20-2015, 06:14 AM | #3 |
2809
Rep 5,316
Drives: G80 M3 6MT
Don't worry so much about the mileage, they do work.
Its a two stage system, here is how it works to the best of my knowledge: The pad wear sensor goes into the caliper and wears away along with the rest of the brake pad, inside the sensor are two metal connections that get made when the sensor material wears away enough, allowing them to make contact. When the first one goes off thats sorta of like an initial warning, when the the second one trips that means you are actually close to needing new pads.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
F32Fleet3571.50 |
11-20-2015, 07:17 AM | #4 | |
Rep 150
Joel
That's a lot of white |
11-20-2015, 08:24 AM | #6 |
Pace Car Driver
1548
Rep 3,164
People tend to overestimate their brake pad use.
Do a visual inspection, it's pretty damn easy. If the pad material is thicker than the backing plate, you're good. If it's less than the thicknes of the backing plate, do some more research and investigating. The E92 M3 I just did, the sensors where on the pads, not the calipers as smithf32 said. |
11-20-2015, 08:31 AM | #7 | |
118
Rep 1,668
Enjoying an E89 Z4, F30 320i and Fiat Abarth //
E85 Z4 (sold), E82 128i (sold), Fiat Pop 500 (sold) |
11-20-2015, 08:40 AM | #8 | |
118
Rep 1,668
11-20-2015, 08:55 AM | #9 |
363
Rep 532
Yup, the sensor has a needle like trigger that is in your brake pads. First warning (yellow) is that you'll need them replace...2nd warning (red), you pads are done and needs replace asap
And for the idrive system, its just a guessimate and those are never accurate |
F32Fleet3571.50 |
11-20-2015, 11:25 AM | #10 |
2809
Rep 5,316
Drives: G80 M3 6MT
Ah right, I knew something sounded backwards about that. 7am answers haha.
Scott, Partner
07-13-2023, 01:37 PM | #11 |
181
Rep 593
Drives: 2018 F48 X1 xDrive 18D
I’ve got the red warning but I don’t have appointment before the end of the month, after you received the red warning. Can I drive another 1000km, what are the consequences with late replacement?
07-13-2023, 04:32 PM | #12 | ||
6659
Rep 15,858
mrpingu180.50 |
07-13-2023, 05:34 PM | #13 | |
181
Rep 593
I am getting the red so I am inclined to believe that is stage 2. I made an appoint when I got the first warning but due to holidays they didn’t have time before the end of this month. Having one trip planned which is about 1000km. |
07-13-2023, 05:43 PM | #14 | |
6659
Rep 15,858
Some models have 2 (Two) stage sensors. They have two data points at about 6mm and 4mm. My understanding either sensor type is indicated to trigger at about 4mm with a 3.7mm minimum. |
mrpingu180.50 |
07-14-2023, 02:24 AM | #15 | |
181
Rep 593
Then I will survive most probably the end of the month and will try to drive more strategic in traffic and use the gear flippers I retrofitted in April If not, I probably will have them to replace the rotors aswell. |
