11-18-2015, 09:41 PM | #1 |
1078
Rep 2,358
Oil pan baffle for the N55
Over on the 1-series forum I have just read what I believe is malfunction due to oil starvation on a N55.
Anyone planning to make a weld-in baffle for our engines? I'll be on the list for a pre-order!
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
11-18-2015, 11:41 PM | #2 | |
1435
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
03-16-2022, 11:34 PM | #3 |
29
Rep 79
This thread deserves to be raised from the dead 🤣
Pussiwillow521.00 |
03-17-2022, 12:06 PM | #4 |
4364
Rep 7,607
AFAIK you just run the M2 pan/baffle setup. https://f30.bimmerpost.com/forums/sh....php?t=1893538
03-17-2022, 02:22 PM | #5 | |
Rep 15
Only affects non xdrive n55 -- from what I've seen mostly from track use. I am no expert, but I believe long left turns can starve the engine as the oil settles with gravity to one side of the pan away from the oil pickup. Again, no expert.. Just what I recall from reading about the issue.... xdrive oil pan apparently acts as a natural baffling system... if you look up the part numbers for the n55 oil pan youll see the difference. |
Poochie9104.50 |
04-28-2022, 08:48 PM | #7 | |
1078
Rep 2,358
Log from GIC in Guangzhou: https://datazap.me/u/harkes/gic-trac...&data=14-17-18 T7 and T8 are the worst as I remember. T7 is trail braking into hairpin left and T8 is full lateral G under load.
(A Dane in China) |
Pussiwillow521.00 |
