11-18-2015, 12:19 PM | #1 |
WRX Betrayer
68
Rep 141
Dinan Springs Just Installed - Creaking/Squeaking
Just had my dinan springs put on this past Saturday along with the supp handling kit. Drove it a good 100 miles so far and still getting a good bit of creaking sounds when turning the wheel....question is how much creaking noise is normal and how long should it last?
Set to get wheel alignment this upcoming Saturday. |
11-18-2015, 03:17 PM | #2 |
55
Rep 272
Were springs installed by Dinan certified installer?
Check this thread http://www.2addicts.com/forums/showthread.php?t=1164914 |
11-25-2015, 11:27 AM | #4 | |
247
Rep 616
12-29-2015, 07:59 PM | #5 |
Supreme Allied Commander
3843
Rep 54,376
Drives: F80 M3
Check the bearing in the upper mount. The plastic bearing doesn't hold up very well to load and debris from the road.
12-30-2015, 01:41 PM | #6 |
WRX Betrayer
68
Rep 141
Turned out to be the guard tube that was left out during the install since they came with new dust tubes. MAKE SURE THE SHOP PUTS THE STOCK GUARD TUBE BACK ON WHEN THEY DO THE INSTALL! The spring was not perching correctly without it thus causing it to "shift", squeak, and creak about when turning.
