KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
02-22-2008, 10:09 PM | #1 |
91
Rep 676
Wheel well gap question
Simple question,
How many inches is the gap in between the top of the fender and the tire with the optional 19's? I hope not as bad as my E46 M3.......... BTW, I ed with no luck. I hope I don't get beat up by the repost crew LOL Chris |
02-23-2008, 01:40 AM | #3 |
O! So Sour!!
552
Rep 15,615
Drives: Fast 240z / Slow M3
it looks the same to me...
02-23-2008, 10:26 AM | #4 |
45
Rep 175
I've only seen picture but guessing F 2.5-3", R 1.5-2". 18"/19" should be the same gap.
2022 M240i | Brooklyn Gray | Red Leather | Black 791M rim| Black trim | HK | Premium | M Lum
02-23-2008, 11:37 AM | #5 |
Commander-In-Chief
2101
Rep 8,911
Drives: 2023 M2 Coupe, 2020 GLE 450
Wheel gap
BMWs, like most production cars, always leave enough room to mount chains at the rear. So, the gap is larger than optimum. I will be looking to lower slightly.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
02-26-2008, 10:46 PM | #6 |
91
Rep 676
thanks for all the info guys
Anybody know the height for sure though? The reason why im asking is because I'm most likely getting aftermarket wheels & am wonderng if it's gonna need a drop (hope not, in fear of Fing w/ my EDC) |
02-26-2008, 11:52 PM | #7 |
45
Rep 175
If you keep 18/19" with the stock dimensions then it will look the same. There are several close up wheel pics on the net. I don't see much reason to change the tire dimensions. On the e46 M3's the tires were too narrow and many went with wider rubber and a lower aspect ratio but this did create more gap. The e92 M3 has wider rubber.
I plan on going with 10" rears so I will go with 275/35/19 vs 265/35/19 stock. If your not going with 20" then you should be fine if you like stock look. Personnaly I hate the stock gap so no EDC for me. I will put coilovers on with about 1" drop for better stance. If you ordered EDC your pretty much stuck with the gap (new springs are not an option, IMHO).
03-01-2008, 12:19 PM | #8 |
1418
Rep 2,560
Drives: Rapidly from A to B
Here are a couple close-ups. Hope they help with your question.
'07 Z4MR '22 GT4 '18 GT3 '16 GT4, '16 M2, '14 X1, '13 135is, '06 330i, '03 323 Ci, '01 330i, '99 M3 (RIP), '96 318is, some non-BMWs
03-01-2008, 12:41 PM | #9 | |||
Commander-In-Chief
2101
Rep 8,911
03-01-2008, 08:02 PM | #10 |
45
Rep 175
Hi Greg,
1) May need to clarify, although the rr is nearly unchanged the gap will look larger, it's more of an illusion. Trust me, when I changed my e46 to wider rubber with same rr as stock the gap looked larger. 2) 19" stock rears are 265/35 3) Good luck with springs but I think it might cost you a few bucks over the long hall for new EDC suspension components. Springs may do Ok for garage queen cars but not daily drivers. The physics will catch up with you eventually. Time will tell I guess....
03-01-2008, 08:20 PM | #11 | |||
Commander-In-Chief
2101
Rep 8,911
03-08-2008, 07:33 PM | #12 |
45
Rep 175
Ok, I saw the car yesterday an measured the wheel gap so can be a little more accurate. F 2.25", R 1.25"
03-08-2008, 10:53 PM | #13 | |
Commander-In-Chief
2101
Rep 8,911
Ride height
1) Measure from fender lip to bottom of wheel. 2) Subtract 1/2 of wheel diameter. 3) Result is "ride height" from axle center. Typically rear dimension is smaller. The reasons for this is its hard to measure accdurately to the top of the tire, and secondly, it take the tire diameter out of the equation.
03-09-2008, 11:23 AM | #14 | |
45
Rep 175
